Linear scales...
Discussion in 'Gage Calibration and Uncertainty' started by Chris Glover, Aug 24, 2015.
  1. Chris Glover
    Chris Glover Active Member
    Aug 7, 2015
    54
    32
    (in the other world known as rulers)...
    We have many instances where a "scale" is called out as the gage used to confirm product quality. How best to "calibrate" or "verify" such an instrument?
  2. BradM
    BradM Moderator Staff Member
    399
    317
    Arlington, TX
    Hello Chris!
    Not sure if you recall the discussions we had at Elsmar on this, but they were quite lengthy and varied in opinions. :)
    So, let's dispense with the argument of whether rulers should or should not be verified, and due to your question, state that they are to be verified.
    I would say it depends on how accurate you need the ruler to measure. If you have a ruler that only needs to be 1/4" inch accurate, then a comparison to gauge blocks, or another ruler (with better resolution, that has been verified against a standard) could be used for verification.
    If you are needing your ruler verified to 2 or more places, I would suggest sending it to a competent vendor. They can verify the ruler using a profile comparator. They can verify from zero on all readings. So... 0 to 1 inch; 0 to 2 inches; 0 to 4 inches; etc.
    i have yet to see a ruler vary much (expansion; contraction), so depending on your needs/ risk/ compliance requirement, I would set the recall to 3-5 years, or only perform an initial calibration of it.
    PaulJSmith and Nikki like this.
  3. Chris Glover
    Aug 7, 2015
    54
    32
    Yep..I agree..there is not really much a steel rule can vary..most of the problems arise from damage and wear.
    What I have done in the past is purchase steel rules with certs (these are available for a few dollars more), set calibration frequency for one year...then at the end of that year replace them with new ones. In the long run this proved to work..and be cheaper than having them "calibrated" by an outside vendor
    PaulJSmith and hogheavenfarm like this.
  4. BradM
    399
    317
    Arlington, TX
    Not sure how many of these rulers you have. But what you could do...
    Is instead of disposing of them, send them off for calibration. What this does is 1) saves the transaction costs of purchasing, disposing, etc.; and 2) now you have data. If you analyze after a year calbration and none of your rulers are changing (as if... they would... :D :) ), then you can justify extending the interval to 2-3 years or longer.
    Chris Glover likes this.
  5. Eric Twiname
    329
    232
    Howdy all,
    I had posted my approach on the "old" thread as well...we use hundreds of rulers, so periodic recheck or even buying a "calibrated" cert cost quite a lot.
    I contacted the ruler manufacturers and they were willing to send me their QC tolerances for manufacture and end of line test.
    The resolution they use for quality acceptance is so much better than we use the rulers for that it is laughable.
    Anything that you might use a ruler for...the mfg specs are way tighter than that (many measured in microns).
    Johnson level & tool
    Starrett
    GEI International
    all were willing to provide product acceptance specs if you ask nicely.
    We "re-verify" based on visual inspection for damage or wear prior to each use (takes ~ 1 second).
    The manufacturer's logo on the scale serves as the calibration mark...no other brands are allowed on site, and no calibration stickers are placed on the scales which might impede use.
    Full defense of approach is kept on file, together with mfr specs.
    Easy, defensible, and has been adopted by some of my customers as well (as opposed to them complaining, they adopted it and saved a lot of money)...
    Note that this approach would never work for end hooks or the like.
    HTH,
  6. BradM
    399
    317
    Arlington, TX
    I like that, Eric! The reasonable/ rationale side of me would say that should be good.
    The "I hate being beat to death in audits" side of me :D would prefer to have something a little more concrete on file; such as a calibration certificate or something from the mfg. for that particular ruler. :)
  7. PaulJSmith
    PaulJSmith Well-Known Member
    107
    113
    Midwestern USA (STL area)
    Ah, the rebirth of the ruler/scale thread. It had to happen sooner or later.
    I, personally, love Ninja's idea. Think I'll propose that for our scales.
  8. Eric Twiname
    329
    232
    I hate being beat to death in audits too...I think if this scale topic ever reached that stage, I would remind them that I had a 24" x 2" steel ruler that I would be glad to show them repeatedly and forcefully for durability testing...o_O
    drgnrider, ncwalker, Mike W and 3 others like this.
  9. ncwalker
    170
    Another "Clouding the issue with logic" thread ... :)
  10. drgnrider
    drgnrider Member
    Nov 30, 2015
    44
    Kansas, USA
    We had an auditor ask us this, our response was basically: Tape measures typically don't last more than 9-12 months and we have at least three different tape measures check any given part/product, (not limited to: operator, supervisor, inspector), if these agree within 1/16", then all is good. If any is off, a NEW tape measure is obtained and then any that are in error are discarded.
  11. Eric Twiname
    329
    232
    Does this not still require the "NEW" tape measure to be calibrated/validated? It must cost quite a bit...
  12. RoxaneB
    In a previous life, we also applied the 1/16" tolerance perspective. ... but ... it was discovered during our certification audit that the 1/16" increments on the tapes only went up to a certain length and then, for some reason, the increments changed to 1/8". Unfortunately, the dimensions that the tapes were being applied to were up where the tapes were in the 1/8" increments. :oops:
  13. Mikegrow
    Mikegrow New Member
    Oct 13, 2020
    Hey buddy, if you are looking for best ruler or scale when i can suggest you. Some best steel scales for any work would be
    Digital Angle Finder Protractor 7 Inch Stainless Steel
    Starrett C604RE-6 Spring Tempered Steel Rule
    Starrett C305R-6 Full Flexible Steel Rule
    These 3 are my top picks after considering there pros, cons from this guide about rulers and scales. I recommend steel ruler because
    It is suitable to be used for indoor and outdoor measurement
    and also gives both standard and metric measurement
