process defects ppm
Discussion in 'SPC - Statistical Process Control' started by samy aly, May 15, 2024.
  1. samy aly
    samy aly Member
    Dec 26, 2023
    25
    assalamu alykom everyone
    wanna know the best way to calculate process defects ppm. The situation is, the factory consists of separate production cells, every cell makes a step in production and has a number of machines , not all the input necessarily turns into out put , every cell has it's own input and output i.e not consecutive production steps like assembly production lines
    669
    726
    PPM? Or RTY?
    Can you explain the situation better? Is each cell making a completely different product or are they just performing different steps for he same product? Does every unique product go thru the all of the cells?
  3. samy aly
    samy aly Member
    Dec 26, 2023
    25
    PPM? Or RTY? i don't know RTY Is each cell making a completely different product no are they just performing different steps for he same product yes Does every unique product go thru the all of the cells? mostly yes
  4. Miner
    647
    556
    RTY is Rolled Throughput Yield
    If you have three sequential operations for the same product, and each operation has a 90% (.90) yield, the RTY = .90 x .90 x .90 = .729 (72.9%) RTY. If the products are different, RTY does not apply.
    samy aly and Andy Nichols like this.
  5. Bev D
    669
    726
    So the easiest way to calculate the defect rate (ppm is not advised unless you are making at least a million units a week; other wise use a percentage for the defect rate) is to add all defects in a group of parts divided by the number of parts started. It’s not mathematically perfect but as long as the # of lost parts are not too large it will be close enough to be insightful. If the number of lost parts is large you can calculate the fraction of defects by started parts at each work station then combine using the proper fraction mathematics. OR just use RTY as Miner described above - it is the preferred way due to mathematical correctness and ease.
    One clarifying thing about MIner’s response is that YIELD = #parts - #DEFECTs. So if you have 100 parts and there were 10 defects at any station then the yield = 100-10 = 90%
    samy aly, Andy Nichols and Miner like this.
  6. samy aly
    samy aly Member
    Dec 26, 2023
    25
    super like
  7. samy aly
    samy aly Member
    Dec 26, 2023
    25
    thanx a lot Bev , i think i will use RTY , it's easier to persuade management with it
