Employee satisfaction survey
Discussion in 'ISO 9001:2015 - Quality Management Systems' started by Nizar, Sep 12, 2022.
Tags:
  1. Nizar
    Nizar Member
    Sep 12, 2022
    Hi every one,
    im looking for Employee satisfaction survey Tempale,
    thank you all.
  2. tony s
    Welcome to QFO.
    I hope somebody here can share to you what you are looking for. But, why are you looking for it?
    Satisfaction surveys or questionnaires are typically formulated by the "satisfaction pitcher" from the needs and expectations of the "satisfaction catcher". If you need to have this form, you need to determine first the needs and expectations from the viewpoint of the "catcher".
  3. Jennifer Kirley
    Welcome Nizar!
    There are three factors when looking for employee satisfaction: Comfort, compensation, and quality of work experience.
    The first two area easy to ask about. For quality of work experience, I always suggest NIST survey Are We Making Progress?
    I suggest you compare the answers among shifts if you have different shifts.
    Enghabashy and Nizar like this.
    5,110
    Before considering an employee satisfaction survey, consider this: are your management prepared to do something about employee dissatisfaction they learn about from the survey?
    pkfraser and Nizar like this.
  5. Nizar
    Nizar Member
    Sep 12, 2022
    Thank you @tony s
    Im looking for it becouse this is one of the actions of the prject of the iso 9001 certification action plan. we did the survey for our client but the auditor told us that we should add more parties like our supplier or our employees
  6. Nizar
    Nizar Member
    Sep 12, 2022
    thank you @Jennifer Kirley that was very helpful to me.
  7. Nizar
    Nizar Member
    Sep 12, 2022
    Yes of course, and this is the purpose of this action, to mesure the degree of satification of the employees and to act about it.
  8. BradM
    BradM Moderator Staff Member
    397
    316
    Arlington, TX
    Hello Nizar! Welcome to the forum!!
    I hope that... you understand at some level we are here to help. So when we throw more questions towards your way, it's not that we're not trying to get you what you want. Rather, we sincerely are interested in your success.
    Surveys are a bit of a tricky thing. Before addressing it's administration, scoring, response rate, etc. one must start with a fundamental question:
    What are you trying to measure?
    For employee satisfaction surveys... is this.. 1) satisfaction in life, 2) in work-life balance, 3) with current management 4) with workload 5) with some initiative the organization undertook, etc. Or is this a survey that will be given on a routine basis and measure the same things (constructs)?
    Once you figure out what you want to measure, you have to develop valid constructs for those things. Otherwise, you'll be sending out surveys and gathering results, but you may not be measuring what you think you're measuring. :)
    So here's my suggestion...
    Give some thought as to why this survey is going to be given; what is the real need? Second, does this survey have upper management support and encouragement? And third, how quickly do you need results and how much resources will you have to help?
    If you can provide that information, it might be easier for us to help guide you more accurately. :)
    RoxaneB, tony s, Nizar and 1 other person like this.
    5,110
    To add to Brad’s post, the best surveys are very carefully designed and are frequently best designed and the survey conducted by specialists. Be careful of simply taking someone else’s without knowledge of their expertise.
    Nizar and BradM like this.
  10. BradM
    397
    316
    Arlington, TX
    Exactly. And not knowing what that survey was validated to actually assess or measure.
    Andy Nichols and Nizar like this.
  11. Nizar
    Nizar Member
    Sep 12, 2022
    hello @BradM i understand your point and im very thankful for you all, and very happy to be one of you.
    regarding my demand it come after an audit of certification 9001.
    the auditor recommend to perform employees and suppliers survey satifaction to the customer one already done.
    he told us isnt enough to made only one, we shoudl mesure the satification for more parties.
    that way im looking today for an exemple to get some insperation.
    and regarding you question about what im trying to mesure : is about Quality of working life in general.
    BradM likes this.
  12. Andy Nichols
    5,110
    Your auditor should not be making such comments or recommendations. ISO 9001 does NOT require such things and it is breaking the rules for the Certification auditor to be suggesting that you go beyond what ISO actually states.
    Yes, employees and suppliers are interested parties, but the standard doesn't say you have to satisfy them, not does it suggest you need to measure their satisfaction.
    Please stop you inquiry and any actions regarding employee satisfaction. There are other things you can directly measure without a survey, which will tell you information about your employees.
    Nizar, tony s and Bev D like this.
  13. Bev D
    606
    664
    Andy is correct there is no requirement in any standard to survey your Custoemrs, suppliers or employees. And you auditor shouldn’t the suggesting that you do things in an y particular manner.
    In fact Customer and supplier surveys have been shown over and over again to be not only useless but actually annoying to the suppliers and customers unless your customers are end commercial users and not manufacturers.
    In the case of employees and end users how the survey is written, analyzed and responded to is critical and not easy or obvious. These should never be homegrown - only professionally and skillfully done. Otherwise you do more damage than good.
    pkfraser, Nizar and Andy Nichols like this.
  14. Jennifer Kirley
    I agree the auditor is being prescriptive. This is frowned on by accrediting bodies. Besides being considered consulting, the advice is limiting. There are even better ways to take in employee contributions than predefined questions, or even the blank spot after a question that hardly anyone ever fills out.
    Nizar likes this.
  15. tony s
    Your organization's management will need to ask the following:
    • Is there a requirement from the standard about employee satisfaction survey?
    • Do we need this?
    • Is this approach the only way to obtain information from the employees?
    • Will it add value to our operations?
    If your organization's management answers NO to all of the questions above, then follow the advise of @Andy Nichols - scrap the suggestion of the auditor.
    Nizar likes this.
  16. Nizar
    Nizar Member
    Sep 12, 2022
    so what should i do to be compliant with this : 4.2 Understanding the needs and expectations of interested parties ?
  17. tony s
    You can use the recommendations by ISO/TS 9002:2016 (Guidelines for the application of ISO 9001:2015). The guideline specifies:
    "To understand the needs and expectations of relevant interested parties, several activities and methods can be carried out. They include working with those responsible for the processes or by using methods that allow the gathering of information. Methods include, but are not limited to:
    — reviewing orders received;
    — reviewing statutory and regulatory requirements with compliance or legal departments;
    — lobbying and networking;
    — participating in relevant associations;
    — benchmarking;
    — market surveillance;
    — reviewing supply chain relationships;
    — conducting customer or user surveys;
    — monitoring customer needs, expectations and satisfaction."
    Jennifer Kirley, Bev D and Nizar like this.
  18. Andy Nichols
    5,110
    Sit your management team down and discuss a) who are interested parties and b) what are their needs and expectations. It's not difficult. Typically, they are:
    Customers
    Stakeholders (owners)
    Management (if not the above)
    Employees
    Suppliers
    (Regulatory agencies, if applicable to the product)
    What do they need/expect?
    Quality products, delivered on time
    Profitability
    Efficiency and effectiveness, low cost etc
    Good place to work, good money, no frustration
    Good price for products sold, no hassle
    Compliance
    tony s and Nizar like this.
  19. Bev D
    606
    664
    You can start by asking them and then LISTEN to what they are telling you.
  20. BradM
    397
    316
    Arlington, TX
    Got it!! Like the others said... honestly... the auditor doesn't need to be requiring that of you.
    Going to a research school, proper methods were.... drilled into me. So surveys... are very very tricky and hard to validate and get good response rates.
    If your management is serious about it, have them pay survey monkey for a validated survey and to administer it.
    https://www.surveymonkey.com/mp/employee-satisfaction-surveys/
    Nizar and tony s like this.
