Correction Factor
Discussion in 'ISO 17025 - Calibration and Test Laboratories' started by Killian O'Leary, Mar 16, 2021.
  1. Killian O'Leary
    Killian O'Leary Member
    Nov 23, 2020
    Hi Everyone,
    We are carrying out in-house fridge/freezer calibrations and i have a question regarding use of the the correction factor. When calculating the correction factor for the below reference temperature measuring device, should i find the difference between the 'Range" and the "As Found" data? Or should I be using the difference between the "Std/Nominal" value and the "As Found" data. In either case, what is the correction factor @0C and 25C?
    Much thanks in advance,
