8.7.1.4 & 8.7.1.5 control of rework/repaired product
Discussion in 'IATF 16949:2016 - Automotive Quality Systems' started by Carlee Gruizinga, May 6, 2025.
  1. Carlee Gruizinga
    Carlee Gruizinga Member
    Oct 18, 2021
    21
    Portage, MI
    Good morning,
    How do you define rework and repair? We wanted to make sure that we are defining these terms correctly and meeting what others do in industry. On of our customers has updated their requirements were we must notify/receive approval from them prior to starting rework.
    Thank you!!
    -Carlee
    IATF definitions:
    • REWORK is an action taken on nonconforming product to make it conform to requirements. A product may be nonconforming at any point within the process.
    • REPAIR is an action taken on nonconforming product to make it acceptable for use. It may not conform to requirements. A product may be repaired at any point in the process. Repairs are higher risk than rework.
    There are several good discussions on this on our sister forum. More recent discussion.
  3. qmr1976
    qmr1976 Well-Known Member
    Jun 17, 2019
    192
    97
    We define rework more like re-processing of part to where it has to be introduced back into production but still meets customer specifications. Any work performed on the part that would be outside of customer specifications generally requires some sort of deviation and can be considered repair. We very rarely do any type of repair on our products, and generally only refer to rework as reprocessing to avoid having to request customer approval.
    Hi Carlee!
    To give a concrete example:
    A hole produced in a component is found undersize may be reworked (processed again) to make the hole the correct size to the specification.
    A hole produced in a component is found oversize may be repaired by adding a filler "plug" of material and the hole reprocessed to the correct size.
    One has more "risk" associated with it (for various reasons) and the customer needs to be aware and know the method chosen closely controlled and approved.
    John C. Abnet and Bev D like this.
  5. Bev D
    In aerospace at least Andy’s definition is the best. But each industry has its own spin.
