What does a "Range of 0.080 Rad" mean?
Discussion in 'GD&T Standards and Practices - ASME & ISO' started by mrode, Nov 18, 2015.
  1. mrode
    mrode New Member
    Nov 4, 2015
    On a recent print we received, there is a designation of a "Range of 0.080 Rad" with an arrow pointing to the center of an indented area similar to: \_____|___|_____/ (Imagine an arrow between to two straight lines.) There may be a hole in that area. We can't tell.
    444
    345
    RAD is typically used on engineering drawings to mean Radius.
  3. Emmyd
    Emmyd Member
    38
    37
    Tennessee
    They may be referencing a notch to eliminate burrs or some other tooling condition.
  4. DavidD
    DavidD Member
    Sep 30, 2015
    24
    It sounds like it might be indicating in what area the radius needs be in. In this case, the 0.080 radius (hole?) needs to be between the two straight lines.
    David
  5. ncwalker
    168
    It is very hard to tell from the ASCII sketch. :)
    I do not disagree that RAD could mean "Radius" but here is an alternate theory. First, look at the phrase "Range of 0.080 Rad". I don't often see a range applied to a radius in this fashion, and my experience is the common designation of a radius is just "R" and not "Rad". It could be that this is "radians" which would be about 4.5 degrees.
  6. Jamie Lill
    Jamie Lill Member
    Mar 17, 2016
    35
    When in doubt ask the customer for a written reply. Not all customers can withe the language of engineering drawings. They add in there own words
    hogheavenfarm likes this.
