Turtle diagram for processes
Discussion in 'IATF 16949:2016 - Automotive Quality Systems' started by Leon Oosthuizen, Jan 9, 2018.
  1. Leon Oosthuizen
    Leon Oosthuizen New Member
    Dec 11, 2017
    Will it be sufficient to show the external auditor with this type of "turtle" and content for each process? I will be including each clause number into each description as well.
    Examples and comments are welcome.
  2. Serious Man
    Serious Man Active Member
    Oct 24, 2017
    79
    28
    I suggest - do not think about external auditor, think about requirements and how they can help your organisation.
    Vital item of turtle diagram is turtle itself. I do not see guts, just limbs.
    Additionally some items are improperly placed, e.g. raw materials.
    yodon likes this.
    Agreed with Serious Man's comment about showing any external auditor anything. What they "accept" is open to too much variation in their understanding.
    I would never, ever suggest using Turtles for anything, except soup. I've yet, in 20+ years, seen an effective QMS documented in such a fashion. They miss a key point which is the sequence of the interacting (mainly support) processes. Filling "buckets" labeled "Who", "With what" and so on isn't how an effective QMS works. A far better method is to develop a proper process map (NOT a flow chart) or value stream map (like a Lean implementation would) to see the way a process actually works - warts and all. Only this provides a true picture of the process and will show improvement needs.
    johnnymo77 and RoxaneB like this.
  4. Raffy
    Raffy Member
    Nov 5, 2015
    Philippines
    With regard to turtle diagram, is it a requirement as part of the Internal Audit process to use? If not what could be the alternative that I may use aside from checklist? Please advice. Thank you very much in advance.
    Best,
    Raffy
    No. You can use whatever you wish. I find just marking up a procedure or process map etc with a highlighter works (but I've been auditing for 30 years)
  6. Raffy
    Raffy Member
    Nov 5, 2015
    Philippines
    Hi Andy, thank you for your immediate response. In marking a procedure or process map, will the said documented information enough evidence to show to an auditor?
    Thanks in advance.
    Best,
    Raffy
    Who knows what an auditor will be satisfied with? It's impossible to tell. Better ask yourself, is this going to be suitable for us to do an effective audit? Doing things to satisfy an auditor is the wrong goal.
