Single Replicate DOE Help
Discussion in 'DOE - Design of Experiments' started by TLL86, Oct 19, 2017.
  1. TLL86
    TLL86 New Member
    Oct 19, 2017
    I am looking for help in improving my single replicate DOE's. In my position at work I use Computational Fluid Dynamics (CFD) to design and optimize product designs. I would like to utilize more DOE's, but one downside to analytical methods is I only get a single replicate because if I run the problem again I will get the same results. However when I run a fractional factorial analysis in Minitab on the data I end up with not enough degrees of freedom to get my P-values for the factors. I have tried added a center point but it doesn't seem to help my results either. I had this issue on an 2^6 8 run DOE and I am currently planning a 2^10 32 run with a center point but want to try and avoid the issues I have had in the past. I would greatly appreciate any ideas or recommendations anyone has.
    Thank you,
    Tony
    If I understand your post, it sounds like these are computer experiments that provide deterministic results with no variation. Is that correct? If this is correct, do you have an estimate of the variability in results that would be seen in the physical world versus in a simulation?
