R-sq vs. R-sq (pred)
Discussion in 'Capability - Process, Machine, Gage …' started by essegn, Apr 11, 2020.
  1. essegn
    essegn Member
    Feb 5, 2016
    47
    I have quick-checked a quite big data set, if there is a sense to spend time on the deeper analysis.
    I would like to know, if any predictor(s) are able to explain the response.
    I choosed the PLS Regression - with Cross Validation.
    I have included all the predictors without checking significance - without 2-way interactions.
    The results are:
    R-sq - 65% with 4 components
    R-sq (pred) - 0%
    R-sq is the percentage of variation in the response that is explained by the model.
    R-sq (pred) - Predicted R-sq
    What does it mean for the process?
    With the data i can explain 65% of variance in the response.
    But the predictive ability is 0% - or near to 0%.
    How could be such an information used?
    Okay, 65% could be explained, but in case that the predictive ability is 0%, then there is no need to spend the time on the process improvement (with the actual data)?
    474
    383
    There are three versions of R^2 used in regression to assess the adequacy of the model:
    • R^2: As you stated, R^2 is the percentage of variation explained by the model. However, it has a very serious drawback in that as you add terms to the model R^2 will continue to increase even when the terms add no value
    • R^2 (adj): Enter R^2 (adjusted). The adjustment penalizes you for adding terms. Therefore, it only increases when the term added adds value. Otherwise, it will decrease. However, you can still add a term that appears to add value, but actually creates a more complicated model that over-fits the data.
    • R^2 (pred): Enter R^2 (predicted). This protects against over-fitting your model, which is what you appear to have done. It uses a portion of your data to predict the unused portion and assess the quality of the prediction. In your case, choose a simpler model with fewer terms. Your results may be so poor due to experimental noise, measurement variation, missing terms, etc.
    Marco2mac and essegn like this.
  3. essegn
    essegn Member
    Feb 5, 2016
    47
    Thank you Miner.
    You are right. I forgot to delete one outlier, this is why the predicton was so poor.
  4. Miner
    474
    383
    Do you know the reason for the outlier? Bad measurement, transposed digits? If you don't know the reason, you should be careful about removing an outlier.
  5. essegn
    essegn Member
    Feb 5, 2016
    47
    I suspect that the outlier was caused by a typo. 105 instead of ca. 1050. However i need to compare the value with the measurement file.
