Question to Outline
Discussion in 'Documentation Control, Procedures, Templates,...' started by essegn, Oct 17, 2016.
  1. essegn
    essegn Member
    Feb 5, 2016
    47
    Dear Sirs,
    I write a Six Sigma Study, but i have a problem to do make an Outline.
    1. Introduction
    2. Methology
    2.1 Define
    2.2 Measurement
    2.3 Analysis
    2.4 Improvement
    2.5 Control
    3. Conclusion
    4. References
    I made an improvement with measurement equipment.
    So should it be written like following?
    2.2.1 Define
    2.2.2 Measure
    2.2.3 Analysis
    2.2.4 Improvement
    2.2.5 Control
    I made an improvement in a process.
    Then I measured the process, it was much better but still not good enough.
    2.3.1 Analysis
    2.3.2 Improvement
    Then I made another improvement.
    The process was after the improvement measured and was better like before.
    2.3 Analysis
    2.4 Improvement
    2.5 Control
    It seems to me bad, because 2.3. is behind 2.3.1.
    Could somebody help me out how to figure it out?
    Or it would be better to join results from both improvements into a one?
    Thank you in advance
    Peter
  2. normzone
    normzone Well-Known Member
    137
    77
    I can't be of any help with this, [Peter], but I think I'll bump up the magnification on my display.
    I saw your post title in the sidebar and I thought it said " Question to outlive " ... I thought " Wow, that's got to be one heckuva question ! "
  3. essegn
    essegn Member
    Feb 5, 2016
    47
    Or it should be like that:
    1. Introduction
    2. Methology
    2.1 Define
    2.2 Measurement
    2.2.1 Define (MSA)
    2.2.2 Measure (MSA)
    2.2.3 Analysis (MSA)
    2.2.4 Improvement (MSA)
    2.2.5 Control (MSA)
    2.3 Analysis - TEST 1
    2.4 Improvement - TEST 1
    2.5 Analysis - TEST 2
    2.6 Improvement - TEST 2
    2.7 Control
    3. Conclusion
    4. References
    Thank you in advance.
    Peter
  4. RoxaneB
    924
    1,072
    Would it be correct to say that you followed DMAIC...made some adjustments...ran DMAIC again...made some improvements...ran DMAIC for a third time?
    Personally, I think I would be a bit confused while reading your Six Sigma Story. If my first statement was correct, I would suggest using Section 2 to describe the DMAIC steps and the actions that you took, including the re-testing.
    Then I'd have:
    3. INITIAL RUN
    • 3.1 D...
    • 3.2 M...
    • 3.3 A...
    • 3.4 I...
    • 3.5 C...
    4. TEST 1
    • 4.1 D...
    • 4.2 M...
    • 4.3 A...
    • 4.4 I...
    • 4.5 C...
    5. TEST 2
    • 5.1 D...
    • 5.2 M...
    • 5.3 A...
    • 5.4 I...
    • 5.5 C...
    6. CONCLUSION
    7. REFERENCES
    That said, if you have to stick to the numbering system of 1-4 in your original post, I would put a table into section with column headers of INITIAL RUN, TEST 1, TEST 2
    essegn likes this.
