QP-822 "Internal Audits" does not jive with "Internal Auditor Checklist"
Discussion in 'ISO 19011 - Auditing Management Systems Guidelines' started by Steve Ball, Feb 27, 2017.
  1. Steve Ball
    Steve Ball Member
    Feb 27, 2017
    Newbie to ISO... I am simply trying to "read the directions" and perform an internal audit at my company. When I read QP-822, it directs me to audit "areas" and the "processes" associated with those areas. QP-822 further instructs an auditor to use the Internal Auditor Checklist, a 1/2" thick document. (We are a typical durable goods manufacturing company.)
    Problem 1: Auditing seems to be all about "areas". To me, an area is either Production, Management, Finance, Engineering, or Quality. Am I correct?? How many processes must be audited?
    Problem 2: When I attempt to audit a process, the questions in the Internal Audit Checklist don't seem to be a basis for auditing a process. What am I missing???
  2. RoxaneB
    Welcome to QFO, Steve, and congrats on your first post!
    Let me get the obvious out of the way first...you should probably have some training on how to conduct an audit. This can be done in-house (especially if you have a seasoned auditor there) or externally (lots of courses out available and finding the "right" can be a bit of a task, but I'm sure you can receive plenty of suggestions on here! :cool:)
    We can't really speak to your "areas" or "departments" because it can vary from company to company. And some organizations include non-traditional Quality Management System areas because they've developed a BUSINESS Management System. Still, you're on the right track in terms of "area".
    That said, "process" is a bit different. Document Control is a process. Management Review is a process. Product Design is a process. What I typically for a management system is develop a matrix that shows all of our areas/departments along one axis and all of the processes along the other. Then I indicate if there is a Direct/Owner or Support/User link between each area and process.
    For example, Production, as an area, is probably a User of Document Control...whereas the Quality area maybe the Owner of the Document Control process. This means Quality has defined the activities and controls within Document Control and Production, as a User, is audited to how well they conform to Document Control. In my experience, Production has their own document authors who are trained on ensuring their documents are properly maintained within the document control software that my organization uses and is responsible for coordinating the training on such documents.
    Without knowing what the questions look like on the checklist (sorry, I didn't look at your attachments), it may be difficult to say but using my example from above, let's try pretend we're auditing Document Control out in Production
    Checklist Question 1 - Is there a document control process?
    Production - How do they create their work instructions?
    Checklist Question 2 - Are documents are made available to people?
    Production - How do people know how to do their job? Are docs available to personnel via computer or hard copy? How do they know they're using the most relevant document?
    Checklist Question 3 - Are records considered as documents?
    Production - What kind of records with product information are generated? How are they maintained/safeguarded? Why does this matter?
    Checklists are all well and good. They're a great starting point for an audit, however, part of successful audit is understanding what you should be seeing and how the checklist questions apply to the area you're going to audit. I refer to audits as "tea-time conversations". If I read off of the checklist, it would annoy me and confuse the person to whom I was asking questions. Consider how the questions can be reworded into normal, every day language that your organization will understand (presuming the questions are simply a repeat of the standard).
    Raffy, tony s and Andy Nichols like this.
    5,459
    Steve: Welcome and I feel your pain. Have you had any practical training in auditing? If you mean you're trying to figure out what to do from reading the attachments, I'd suggest (as my colleague Roxane does) that you stop and instead find some hands on training. Such templates rely heavily on you having understanding (or not) and, in fact, the checklist is simply the ISO 9001 requirements turned into questions and, as such are merely one way to do audits (and not really what internal audits are about, which is your OWN QMS).
    To answer your question DIRECTLY, the "scope" and/or criteria of the audit can be:
    • a process
    • an area
    • a project
    • a contract
    • a regulation (if applicable)
    • an ISO requirement (especially if new)
    • a procedure/instruction
    • or any combination of the above
    It depends on what management consider to be important...
    Bottom line - get some training in a class with a real, experienced instructor who knows the difference(s) between internal audits and CB audits and knows how to do real internal audits.
  4. Steve Ball
    Steve Ball Member
    Feb 27, 2017
    Thanks for such a comprehensive reply!!! I agree that training may be beneficial and would appreciate a recommendation for something quick that I can do in an hour or two online. Suggestions?
    So far as "processes"... I have all "Procedures by Work Area" documented. My understanding is that "procedures" and "processes" are synonyms. Ex. Procedure: "Incoming Raw Material Inspection". This is a written procedure used in our Production Dept. but
    authored by the QC Dept. My understanding is that QC cannot audit its own work, but an auditor based in the Production Dept. can audit this procedure/process.
  5. Steve Ball
    Steve Ball Member
    Feb 27, 2017
    Oops. Please disregard that reply, Andy.
  6. Steve Ball
    Steve Ball Member
    Feb 27, 2017
    So far as "processes"... I have all "Procedures by Work Area" documented. My understanding is that "procedures" and "processes" are synonyms. Ex. Procedure: "Incoming Raw Material Inspection". This is a written procedure used by our QC Dept. and authored by the QC Dept. My understanding is that QC cannot audit its own work, but an auditor based in the Production Dept. can interview a QC person and audit this procedure/process. Right?
    Where I'm getting hung-up is the 1/2" thick Internal Audit Checklist...which I agree is simply the Standard converted into questions. How does anyone use the beast to audit a process?? I think I need to forget using this document altogether.
    Our company's QMS...right or wrong...I inherited it.... We took the Standard and simply "responded" to the enumerated requirements of the Standard by simply listing our company's Quality System Procedures that would cause us to comply with the Standard. I makes perfect sense that those internal Quality System Procedures are what I need to be auditing. (See? I said I was a newbie.) NOW I think I know what to do. I'll audit those internal procedures that cause compliance......if we're good on the audits, then we comply with the Standard!!
    Do I have this kinda-sorta right??
    5,459
    Sadly that's a practical impossibility. Most worthwhile courses are 18 - 24 hours in duration.
    Exactly!
    Are you located in the USA?
  8. Steve Ball
    Steve Ball Member
    Feb 27, 2017
    Thanks for that confidence builder! I'm down South in Alabama. (We've got 100 lb catfish here, you know.)
    Now that I have a basic conceptual understanding of process audits, there may be a few more questions on the more routine stuff such as corrective actions and such.
    Thanks again and again!!
    -Steve
    5,459
    In essence, Steve, to do a process audit you take a look at:
    • The plan for the process (for a manufacturing process, the quantity of product to be produced that shift, day, week etc)
    • The inputs to the process
    • The controls for the process
    • The product and process measurement - and/or monitoring carried out
    • The output of the process, then compared to the plan.
    • The way non-conforming product is handled
    • And so on...
    For a bit of reading, try here: https://www.nqa.com/en-us/resources...-implementing-iso-9001-step-5-internal-audits
    and here: https://www.nqa.com/en-us/resources...01-2015-using-your-qms-part-5-internal-audits
    and I had also written an article on doing process audits but can't find it on the NQA blog (my last employer). If I can find the original I'll post it to my personal blog.
    Since you are in AL, why not try the AL MEP (I'm with the Michigan MEP) and try their training: http://www.atn.org/OurServices.aspx?sid=6
  10. Steve Ball
    Steve Ball Member
    Feb 27, 2017
    Thank you, Andy. I'll take a look at AL MEP for training resources.
    -S
