Processes vs manual
Discussion in 'ISO 9001:2015 - Quality Management Systems' started by Mohammad, May 16, 2016.
  1. Mohammad
    Mohammad New Member
    May 16, 2016
    Hi all
    Please if some one can help me to explain differences between these elements which are :
    1. manual
    2. Process
    3. Procedures
    It will be highly appreciated and thanks for all of you
  2. Randy A. Kaczynski
    Randy A. Kaczynski Member
    Per ISO 9000:2015 -
    3.8.8
    quality manual
    specification (3.8.7) for the quality management system (3.5.4) of an organization (3.2.1)
    3.4.1
    process
    set of interrelated or interacting activities that use inputs to deliver an intended result
    3.4.5
    procedure
    specified way to carry out an activity or a process (3.4.1)
    Note 1 to entry: Procedures can be documented or not.
  3. RoxaneB
    924
    1,072
    Mohammad, do you mean 'process' or 'process map'?
  4. Chris Glover
    Chris Glover Active Member
    Aug 7, 2015
    54
    32
    or maybe process approach?
  5. RoxaneB
    924
    1,072
    Possibly that, as well...with the other two items being more 'documentation' in nature, I'm leaning towards process map, but hopefully Mohammad will come back and clarify. :)
  6. pkfraser
    pkfraser Active Member
    Aug 1, 2015
    88
    56
    Aberdeen Scotland
    1. As Randy points out, ISO9000 tells us that a "quality manual" is "a specification (a "document stating requirements") for the quality management system of an organization". There are two problems with this:
    i) ISO9001:2008 listed (in 4.2.2) a number of items to be included in a manual, none of which was a "requirement for a QMS".
    ii) ISO9001 states that the "quality management system requirements specified in this International Standard ..." - ie it is a "document stating requirements for a quality management system", which would imply that ISO9001 is a quality manual. Which it isn't. So the ISO9000 definition is flawed.
    Fortunately, the requirement for a manual is no longer in the standard. In practice, most organisations nowadays have an electronic system which contains all relevant details of the system with suitable indexing to make all the elements readily accessible.
    2 and 3. A process is a set of actions ("what you do to achieve an objective"). It is not a description, or a flowchart, or a diagram. And a procedure is a defined or accepted method to carry out an action or process.
