Procedure for Change Management
Discussion in 'IATF 16949:2016 - Automotive Quality Systems' started by sergiu, Aug 1, 2019.
  1. sergiu
    sergiu Member
    Jul 4, 2019
    hello all,
    i want to ask you if you can help me with a procedure for change management to have for exemple to create new one for the company where i work .
    Thank you !!
  2. Jennifer Kirley
    What do you produce? What services do you provide? Are you a toll manufacturer?
    One problem with basing your procedure on someone else's is that your organizations can be so different; if you make a process as complex as some others do, that may or may not be appropriate for your operations. A result could be personnel circumventing the process. Or, something important might be overlooked.
    I agree with Jennifer. It may seem a good idea to see what others have done but it can be a deadly trap. You are making all kinds of assumptions when you ask for an example.
    Why not get a cross functional team of management and supervisors who would be involved in making a change (depending on what you mean by "change") and facilitate a process mapping session (or 3). Make sure there's food. Make certain management support the need and will make time. Be sure to identify where the way you handled change previously didn't work effectively/efficiently.
    Nikki and Jennifer Kirley like this.
  4. sergiu
    sergiu Member
    Jul 4, 2019
    Hello ,
    thank you for replay.
    I have this task from the plant manager. I did not do change management untill now. I wanted to see how it should be done so I can figure out how I can do it on our own. We are at the beginning of the road in the automotive industry.
  5. sergiu
    sergiu Member
    Jul 4, 2019
    hello,
    yeah your right can be deadly trap if i will do without thinking what i am doing the problem for me is that i never did such a thing but i want to understend how is made ,plus the courses are only general .
    Tell your plant management you need to get a team together (since you have never done this before and won't know, even if you get a template if you have got a good one) and because most organizations are affected by changes, let's collaborate and map the process so it suits ourselves.
  7. Jennifer Kirley
    Ask yourself as an interdisciplinary group what could go wrong if changes are made without anyone else knowing about them. There are so many potential examples, including but not limited to:
    • Equipment installation and removal: besides the correct set up of infrastructure (plumbing, electrical safety, planned maintenance, or PM, electrostatic discharge if that applies, environmental concerns) there is a need to qualify the machine to operate satisfactorily and accurately in your quality management system. There are checklists for that. I once audited a facility with an entire room of new equipment, an entire new process; the project had been signed off and running, but not a single PM had been set up.
    • Personnel changes: it seems impossible, but after a re-organization I went to a new process manager and said "Hello, it is time to schedule the ESD audit, and you're the new manager..." he blinked and said, "I am?" No one had told him, trained him or introduced him to the previous manager.
    • Process changes, including in IT: they need to be planned, controlled and validated if they affect your quality management system. How will that be done? I once audited a site whose IT department had migrated them from Lotus Notes to Google Docs. No one has ever been able to describe to me (including them and many afterward) how one can retrieve a document from Google if it disappears overnight.
    All of these things address risks. Your procedure need not be huge, but you do need organized methods to make sure important considerations are addressed.
    I hope this helps!
  8. sergiu
    sergiu Member
    Jul 4, 2019
    thank you for your answer it helps me to understend what I need to do.i hope I can manage this soon until audit.
    thank you so much!!
  9. sergiu
    sergiu Member
    Jul 4, 2019
    to be honest I did that but all of them they dont know.its very hard with them.i hope I can manage this one. thank you so much for your answer
    Someone knows. Maybe you just had the wrong people.
  11. sergiu
    sergiu Member
    Jul 4, 2019
    i think so...i hope i can do it soon.thank you guys for everthing.
