MSA: GRR Multiplication Factor of 5.15 Vs 6
Discussion in 'Gage R&R and MSA - Measurement Systems Analysis' started by shankar Jadhav, Sep 5, 2015.
  1. shankar Jadhav
    shankar Jadhav Member
    Sep 5, 2015
    Historically, by convention, a 99% spread has been used to represent the “full” spread of
    measurement error, represented by a 5.15 multiplying factor (where GRR  is multiplied by 5.15
    to represent a total spread of 99%).
    A 99.73% spread is represented by a multiplier of 6.0, which is 3 and represents the full
    spread of a “normal” curve.
    If the reader chooses to increase the coverage level, or spread, of the total measurement
    variation to 99.73%, use 6.0 as a multiplier in place of 5.15 in the calculations.
    Can anyone explain me?
    606
    664
    what part do you need to have explained?
    Why there is a choice or why the convention changed from 5.15 multiplier to 6? If it's this, there is no real reason for the change - I suppose that some people thought that with "Six Sigma" we should use 6...there is no magical reason. It's really personal choice.
  3. Atul Khandekar
    Jul 24, 2015
    377
    266
    Pune, India
    Having calculated the GRR Standard Deviation, the question is what is the total magnitude (= width = full spread) of this error. The earlier 'convention' was to multiply this StDev by 5.15 (+/- 2.575 std deviation) that covered 99% of the normal distribution. This was later changed to +/- 3 std deviation (multiply by 6, or 99.73% coverage).
    As Bev said, there doesn't seem to be any specific reason for the change. In any case, if your GRR std deviation is very small, multiplying by 5.15 or 6 won't make much difference. The multiplier of 5.15 would yield a slighly understated estimate.
    To calculate the ratio of GRR to StudyVar or Process variation, you can now divide the two standard deviations directly instead of having to calculate their 'spreads' seperately.
