Mind Mapping
Discussion in 'FMEA - Failure Modes and Effects Analysis' started by QMSmaster, Mar 27, 2016.
  1. QMSmaster
    QMSmaster Active Member
    Dec 29, 2015
    Has anyone used mind Mapping techniques for doing FMEA's? We are experimenting with this so I am wondering if anyone else uses this approach?
  2. Claes Gefvenberg
    230
    208
    Eskilstuna, Sweden
    Actually... I started using mind mapping in ernest in the early 80'S, and have since used it for just about anything I can think of, including FMEA.
    I used it as a means to systematically come up with failure modes, and then enter those into the FMEA, but you may have other ideas? Do tell. Maybe we can learn from each other.
  3. Jennifer Kirley
    Can you share an example with us Claes? It sounds interesting.
  4. QMSmaster
    Dec 29, 2015
    We have been experimenting with using Mind Mapping to brainstorm failure modes and causes. Then we enter them into a spreadsheet for the usual RPN ratings. People seem to find the Mind mapping easier to brainstorm and it helps keep them interested. You can move a little faster also.
    FreeMind is the mind mapping SW we use. It is free. http://freemind.sourceforge.net/wiki/index.php/Main_Page
    It is a very useful tool to add to your tool box if you do not do this. You can mind map in Visio but FreeMind is the way to go.
  5. Claes Gefvenberg
    230
    208
    Eskilstuna, Sweden
    That is more or less what I did, and I think it works very well. As for software, there is an abundance to choose from, but I agree that a dedicated mind mapping application should be used.
    Examples... I have not been doing this for a long time, but I will check if I still have something. I would use a mind map to create an Ishikawa diagramme of sorts, and if you branch out five times it also gives you a 5w as a bonus.
  6. Claes Gefvenberg
    230
    208
    Eskilstuna, Sweden
    Ok, I have had a look, and... apparently it was too long ago: I could not find any examples.
