Is 60601-1 mandatory for ALL medical devices ?
Discussion in 'IEC 60601 - Medical Electrical Equipment Safety' started by eddyo, Oct 27, 2015.
  1. eddyo
    eddyo New Member
    Sep 16, 2015
    Hi There,
    Is 60601-1 mandatory for all medical devices or does it depend on the classification/category. The company I work for is currently working on a medical device (classification code "ILY") that will be offered for sale in Canada and the US.
    We will be submitting a 510(k) shortly but only have passed the device through standard CSA electrical testing & 60601-2 (EMC) test. Would 60601-1 be required as well?
  2. Marcelo Antunes
    Marcelo Antunes Active Member
    55
    65
    Usually, no standard is mandatory (they are mandatory only in certain very specific countries such as Brazil, China and Korea). But you may use standards to show compliance with mandatory regulatory requirements.
    IEC 60601 is applicable to all medical electrical equipment (not all medical devices). You may use it to show compliance with several regulatory requirements.
    The "electrical testing" you mentioned is probably IEC 60601.
  3. eddyo
    eddyo New Member
    Sep 16, 2015
    Thanks for the response.
    Our device is an electrical equipment therefore I guess we will require 60601. The current electrical certification we have with CSA is not for medial equipment.
  4. Ronen E
    Ronen E Well-Known Member
    133
    70
    The FDA code ILY comes under class II, and it has a "special control" guidance document (relating to the preparation of a 510(k) submission under this code). This guidance document doesn't mention or hint that 60601-1 certification is required. Obviously there might be safety aspects in the submission that could benefit from such certification, but apparently it's not mandatory. The above guidance document is quite old, but apparently that's still the FDA's reference for that code.
    I'm not familiar enough with the Canadian system to comment in that context.
    Cheers,
    Ronen.
  5. MarkMeer
    MarkMeer Well-Known Member
    Dec 3, 2015
    138
    I made a post the other day, that may be worth considering:
    http://www.qualityforumonline.com/f...-program-make-60601-compliance-mandatory.404/
    Basically, if you intend to market your device to clinics, hospitals, or any other establishments that abide by OSHA, then you'll likely have to have an NRTL mark on the labelling.
    ...and this means that yes, testing to AAMI ES60601-1:2005/(R)2012 by an accredited NRTL will be required.
  6. Peter Selvey
    Peter Selvey Member
    Nov 9, 2015
    Surprisingly Canada is in effect a requirement, although it is state based, not federal. If the local state laws have adopted the Canadian Electrical Code (CEC), it is required to have the devices certified by a recognized agency. However, there are arguments that the scope can be limited to electrical safety issues. Nevertheless, the agency testing the product will probably insist to include a wider scope according to their internal policy.
    The OSHA/NRTL scheme is as mentioned above, not law but effectively required to sell to major facilities through purchasing requirements. As for the CEC, the raw scheme is fairly limited in scope (worker safety), but the test/certification agency will probably insist on a wider scope anyway, at least as wide as what they can do, and then conveniently exclude the stuff they can't.
    In my opinion, a simple reasonable cost scheme which focuses on basic electrical/mech/fire/thermal issues should be created, to avoid the high cost associated with getting 3rd party testing to full scope of modern medical standards, which is extremely wide.
  7. MarkMeer
    Dec 3, 2015
    138
    Totally agreed. As far as I'm aware, OSHA's mandate is to protect workers and establish standards for workplace safety. Ideally, their criteria would be a sub-set of an established safety standard, so that their requirements only deal with workplace safety.
    In the case of getting medical-devices OSHA/NRTL marked, the fact that you have to demonstrate patient safety, as per the medical requirements of 60601-1 to get the mark, to me reeks of mission creep.
    If they want to stick with an established standard (e.g. IEC 60601-1), the least they could do is narrow the scope to exclude all the clauses unrelated to workplace hazards.
