Interested parties and their expectations
Discussion in 'ISO 9001:2008 - Quality Management Systems' started by Siva Prasad, Jul 4, 2017.
  1. Siva Prasad
    Siva Prasad New Member
    Jun 29, 2017
    Hi All,
    I need a clarification in documenting the Interested parties and their expectations. I have identified the stakeholders as Customers, Board of directors, employees etc... to name a few. While documenting their expectation from the QMS, most of the expectations are repetitive. So My question here is...
    1. Do I need to document them elaboratively.( even though there are repetitions)?
    2. Should I mention the Monitoring mechanisms( frequency, Type of review) for all the expectations?
    3. Should I link expectations back to the Mission, Vision, values of the organization?
    Please help.
    Dipcario likes this.
  2. Jennifer Kirley
    I think we can expect overlap on a high level, but there may be details that are specific. For example, Customers, Board of directors, employees can all have needs for abiding by regulations but their perspectives and the specific regulations are different.
    We should not think of this as something that is being considered for the first time. I suspect you know what your customers' needs and interests are, and the Board, and the employees. You don't need to list them all, but the ones that could impact your business should certainly get attention.
    Does your organization have a business plan? If so, it's possible that much of this is already done.
    How often to review is up to your organization. Some issues are certain to be more fluid and some static; some will be urgent and others will be less concerning. Very often I see this being included in Management Review; some can (and might already) be included in more tactical level departmental meetings. If that is the case, why not take credit for it?
    Siva Prasad likes this.
  3. normzone
    normzone Well-Known Member
    137
    78
    (raises hand, eagerly waving) " Ooh, ooh, I think I know this one! Because there's no record of it, therefore it never happened, at least from the auditable point of view? "
    EDIT: My cow orkers often allege having met some requirement in one of the aforementioned tactical level meetings, but ask me if I can take their word for it, since insufficient records are kept of these meetings.
  4. Jennifer Kirley
    I am sure there are managers that run their businesses off of tribal knowledge. And, it should be mentioned that there is no requirement for documented information with this. Where might we find it besides meetings and business plans?
    The design/R&D process
    Contract review
    Customer satisfaction queries
    Sales and order documentation
    Specifications
    Permits
    Insurance policies
    Communications
    Union negotiation process
    Proposals
    Complaints
  5. Siva Prasad
    Jun 29, 2017
    Thanks a lot for the reply. This is indeed helpful.:)
    Dipcario and Atul Khandekar like this.
    Obviously, the queries of @Siva Prasad stem from his interpretation of the requirements within clause 4.2 of ISO 9001:2015. This clause should not be addressed in isolation from the other requirements. Clause 4.1, even 4.2, serves as input to other clauses within the standard. If an organization has a clear "understanding" of the needs/expectations of the interested parties {NOT documentation), then the requirements in other clauses will be better fulfilled. For examples:
    • in 6.2 - organizations will be prevented from setting/achieving objectives where nobody cares about;
    • in 4.3 - organizations with multiple products/services will be guided on what products/services should be included in the scope of the QMS;
    • in 8.2, 8.3 - more suitable specifications and characteristics of the products/services will be determined. etc.
    The standard does not require documented information on both 4.1 and 4.2. Please refer to A.6 of the standard.
    See also related topic on this. https://www.qualityforumonline.com/...interested-parties-matrix-nc.3546/#post-24463
  7. Wins Letshawn
    Wins Letshawn Member
    Aug 9, 2021
    Here is a simple answer to your questions:
    You do not need to write the same thing many times. If the expectations are the same for different groups, you can write it once and say which groups it applies to.
    Yes, it is good to mention how you will check each expectation. You can write how often you will check (like monthly or yearly) and what method you will use (like meetings, reports, or surveys).
    It is helpful to show how the expectations connect to the mission, vision, and values. This shows that the QMS supports the main goals of the organization.
    Hello Wins Letshawn:
    This thread is very old, from 2017 and posted in an obsolete sub-forum. Do you wish your post to be moved to the ISO 9001:2015 forum as a thread starter?
    Good post, Tony. I'd suggest that the simplest, most appropriate vehicle is management review, in whatever form that takes. The same information is supposed to be the inputs for the review, if anyone cares to understand the purpose of the review. No additional need, as you suggest, to write anything down. Certainly no additional reviews should be necessary.
