IEC 61010 for EU Low Voltage Directive
Discussion in 'Other Quality and Business Related Topics' started by Sarah Nuss-Warren, Jul 9, 2019.
  1. Sarah Nuss-Warren
    Sarah Nuss-Warren New Member
    Jul 9, 2019
    We are using the IEC 61010 harmonized standard to certify to the Low Voltage directive. I have two questions about items in the standard and would like to get the community's input on them.
    1) IEC 61010-1 refers to altitude above 2000 m. Is this for instruments to be used in flight, or does it also refer to elevations more than 2000 m above sea level?
    2) IEC 61010-1 refers to clearance and creepage distances as the "shortest distance" with a typical minimum being 0.5 mm. When measuring minimum distances, is it acceptable to round to the nearest 0.1 mm?
