Identical parts with different material compositions
Discussion in 'Manufacturing and Related Processes' started by James, Jan 14, 2016.
  1. James
    James Active Member
    Aug 31, 2015
    50
    Oklahoma
    I'm hoping someone won't mind brainstorming a bit. We will be looking at manufacturing parts that look identical but have different material compositions. Unfortunately the quantities are too low to justify separate manufacturing cells for each. Some of the parts are smaller, approximately 1 inch in length.
    We use routing packages and pallet tags but are considering rubber stamping individual parts to ensure they can't be accidentally mixed. Anyone have some experience with traceability and segregation like this?
  2. Golfman25
    We do this a lot -- same part, different materials. A couple of things to watch for. Certainly, if you can mark the individual parts at the time of production that is ideal. A simple color coding with a sharpie can work. If you can't do it at the production station, then keeping things separate and workstations clean is important. Make sure all of the old part are "gone" before you start the new part. You might also invest in a material tester (I want to say they use ultrasonic sound waves) and add a test to your process downstream. Good luck.
    Jennifer Kirley and James like this.
  3. RoxaneB
    While the production quantities are low, would there a significant bottleneck in the process for individual tagging/stamping/marking? I think the individual marking is probably the safest way to avoid possible mix-ups further down the line. What about colour coding the packaging? Pallet tags are nice, but tags can fall off. Orange bins or pallets for Product 1A and purple bins or pallets for Product 1B? If you are using pallets and the items are stacked on the pallets, what about shrink-wrapping to reduce the likelihood of items falling off and leaving to wonder if it is 1A or 1B?
  4. Eric Twiname
    329
    232
    Just thinking out loud...
    Are the two materials different enough to reliably measure a difference by weight?
    I have two identical looking white plates stored next to each other with no issue. Only the bins are marked. The density of one is 4g/cc, the other is 6g/cc...a simple scale (2 feet away) has no issue telling them apart.
    Most operators can tell the difference as soon as they pick them up due to the weight difference.
  5. James
    James Active Member
    Aug 31, 2015
    50
    Oklahoma
    Thanks for all the ideas, they definitely help. We might go with color coded sharpies and just a quick swipe on each part as they are machined. Then we can use the same color code on the traveler/router paperwork, pallets, and containers. Maybe even color coded tape and/or wrap on the pallets too. Unfortunately the weight is the same, but that's a great point to keep in mind for future stuff.
  6. Miner
    Jennifer Kirley, Emmyd and James like this.
  7. Ronen E
    Ronen E Well-Known Member
    133
    70
    First thing I would look at is making absolutely sure that you actually need 2 different parts. Is the difference in material properties significant? Where do the requirements for different materials come from, and why? Is it still current?
    Could be an opportunity for improvement.
  8. Golfman25
    A lot of times, the same part in different materials are used for different environments. The cheap people use plated steel. More corrosive applications use stainless. And the absolutely, positively, can't have an issue use ultra expensive alloys.
  9. Ronen E
    133
    70
    I guess we won't know unless James will tell us...? ;)
  10. James
    James Active Member
    Aug 31, 2015
    50
    Oklahoma
    Unfortunately that gets into customer intellectual property. But they are using multiple compositions for specific reasons that can't be avoided.
  11. Ronen E
    133
    70
    Fair enough.
    Another thing I would look at, if CNC is involved, is adding a minor feature with one of the tools already involved, e.g. a harmless dimple that can be created with the tip of a drill (you have to make sure that the design is not adversely affected). This could be another (more consistent?) layer on top of human actions, and is more permanent. When investigated complaints where the constituent material is important, it's very handy to be able to easily tell what material was employed, months and years after production.
    James, Eric Twiname and Candi1024 like this.
  12. _Zeno_
    _Zeno_ Member
    Sep 3, 2015
    46
    James and Miner like this.
  13. James
    James Active Member
    Aug 31, 2015
    50
    Oklahoma
    Great idea, we are a CNC shop. Good heads up on color blindness too. Shapes are a great point too.
