IATF IMPLEMENTATION Internal audit scope
Discussion in 'IATF 16949:2016 - Automotive Quality Systems' started by Diego_99atv, May 20, 2020.
  1. Diego_99atv
    Diego_99atv Member
    May 19, 2020
    24
    Hello
    If my company manufacture product for OEM and not OEM costumers theIATF internal Audit shoul be performed for all the Process including not OEM costumers.
    Thank you
    5,459
    Your internal audit program, regardless of your certification, should consider all aspects of your quality management system. Which customers are automotive and which are not isn't really so important (except that some customers may have contractual requirements you have to meet) - what's important is that you do the audits for the right reasons.
  3. Golfman25
    Your audit requirements will be different depending on the the auto/non-auto applications. For your auto applications, you'll need a little more -- make sure you cover customer specific requirements and also that your auditors are competent as specifically required by the standard. The IATF standard and interpretations lay it out pretty good. Good luck.
    Diego_99atv likes this.
