How to reduce scrap?
Discussion in 'Other Quality and Business Related Topics' started by Kristof, Nov 10, 2017.
  1. Kristof
    Kristof Member
    Feb 27, 2017
    26
    Poland
    Hello there,
    Industry: Automotive
    Major product: Brake Discs
    Problem: High level of scraps
    I just started my work as QM in the Automotive industry. In the manufacturing process, we have a lot of scraps (set up of CNC machine).
    How to reduce scraps? What do You use to reduce them?
    I know It's not possible to eliminate them...
    I have an idea to eliminate problems on the production line.
    To realize this I have to build the problem-solving team and arrange regular meetings. I'd like to engage the operator.
    Can You recommend me best tool to eliminate the cause of problems in the fast and easy way on the production line?
    What do You think about Suggestion Board and Problem Board? In Your opinion, It's a good way to improve the process?
    Thank You for feedback.
    Gr. Kristof
  2. Kristof
    Kristof Member
    Feb 27, 2017
    26
    Poland
    The good solution to above problem. Lets me know if I think in a good way:
    1. Monitor Process.
    1. Using Diagram Pareto -> categorize which group of product/ machine generate the highest level of failure/ scrap.
    2. Analyze the most occurs failures using 5Why or other quality tools.
    3. Define countermeasure for causes.
    4. Implement countermeasure for causes.
    5. Verification of result-> once again monitor a process.
    Gr. Kristof
  3. Golfman25
    Maybe a Kaizen event? Start with google.
    You don't "reduce" scrap. You take action on the cause of the scrap. Do you know the reason parts are having defects?
