Documentation of validation and qualification protocols
Discussion in 'Qualification & Validation (Also 21 CFR Part 11)' started by Abdullah, Jan 11, 2016.
  1. Abdullah
    Abdullah Member
    Dec 22, 2015
    18
    Dear all,
    I hope you are having a great time where ever you are ^_^
    i have a question which is:
    when a qualification or a validation protocol for a particular equipment or process is approved and it needs to be executed, where shall the actual readings be written ?? i mean on the same tables and fields within the same protocol or they will be documented on a separate forms the same as those prepared in the protocol.
  2. Somashekar
    114
    98
    Its common to follow the "Protocol" and the "Report" in a validation exercise. So I guess for your question, the separate form as made in the protocol shall have the actual readings being a part of the report. Hope this answers your question...
    Abdullah likes this.
  3. Abdullah
    Abdullah Member
    Dec 22, 2015
    18
    so i need to prepare the protocol with empty tables and forms, then make a report including the same tables and forms to fill the actual results on it ?!
  4. Somashekar
    114
    98
    Yes. The empty tables and forms in the protocol are typical, and can be with just an example field for the data. The report tables and forms runs down to as many trials as you make in your validation attempts. Hope this clarifies.
  5. Vthouta
    Vthouta Member
    Dec 20, 2015
    In my past experience, I have listed all the requirements in the protocols and designed user friendly forms with empty tables and headings. I general, you could report all the findings in the validation report. Summarize the findings and observations recorded as part of the verification and validation process.
  6. Abdullah
    Abdullah Member
    Dec 22, 2015
    18
    ok thats great, but there is one more thing; according to ISO 13485, it is required to control each document according to a documentation system. so do i need to give each protocol / report an issue number, issue date and signature,...etc ??
    or it is applicable to attach the report to the prepared protocol without giving document number ?!!
  7. QAengineer13
    QAengineer13 Member
    47
    I am not sure whether your organization comply with FDA ? If you do please ensure you follow 820.40 (a) Document approval and distribution and (b) Document Changes. Clearly you need to have a unique report document number (DHF #) Revision and author , Reviewer/approver for the report even if its just ISO 13485 or according to 21 CFR 820.40.
  8. Somashekar
    114
    98
    The protocol is your validation document. This revision must be current, and under the document control.
    The report is the validation record. This must follow the most current protocol and be under your records control. You could be making multiple validations and therefore so many reports (records) using the same valid protocol.
  9. Candi1024
    Candi1024 Well-Known Member
    129
    83
    Pennsylvania
    I understand his confusion :)
    At certain companies, we would write a protocol and it would be approved. Then we would use that exact printed protocol and fill out the form (making it a record). The document number on the protocol would therefore be at the bottom of the record, since it is the form. It would be the executed protocol.
    At other companies, we would be required to take the protocol, and change certain things like the footer and the title, to make it into a record with a new document number. Then execute that new document. I have an issue with this but I have a hard time getting others to see it my way. (or maybe my view is just not quite correct, lol!)
    Somashekar and Abdullah like this.
  10. Abdullah
    Abdullah Member
    Dec 22, 2015
    18
    Exactly thats it :p
    Somashekar likes this.
