Difference between die and mould?
Discussion in 'Manufacturing and Related Processes' started by Fahad, Oct 18, 2020.
  1. Fahad
    Fahad New Member
    Oct 3, 2020
    What is the difference between die and mould?
    Typically, it's an industry-sector distinction: a die is commonly used to form (sheet) metal, through the action of closing on the material to press and form it to shape. A mould usually closes and then has material (often plastic) injected. This is NOT a universal terminology, however. For example, when producing die-cast components in metals such as zinc or aluminium (relatively low temperature melting point), the die closes and the metal is poured/injected.
