DFMEA - Scope - Assumption of good design practice
Discussion in 'FMEA - Failure Modes and Effects Analysis' started by Mungo, Mar 14, 2022.
  1. Mungo
    Mungo Member
    Mar 14, 2022
    Hi, I'm new to the forum, although I have been involved with carrying out DFMEAs, on an off, for 20 or so years. Each company and project that I have worked with approaches their DFMEA in a slightly different way, I guess there are subjective to some extent.
    My current project has broadened the scope in a way that I am sure is not correct, may I have your guidance please. I always assume that the product has been subjected to the design review process and so good engineering practice is ensured, i.e. the prototype assembles ok. This project is being directed to include failure modes such 'holes mis-aligned, bolt can't be inserted'; I am adamant that this is incorrect with respect to scope, this is suggesting that good desing practice has not been followed. The associated PFMEA should cover the tolerance stack issue.
    Am I correct here?
    I have been searching for a reference in the manuals for a paragraph that confirms this scope of the DFMEA towards what to assume for the design but unfortunately unsuccessful. The best that I can find is the AIAG HB 1st ed extract below, but I am looking for a clearer directive to the state of the design on which to base the DFMEA.
    Please let me know if you know of a reference to this scope and assumptions aspect.
    PhilD313 likes this.
    578
    In a design FMEA, your only assumption is that the design is manufactured and assembled to the design intent (as you found above). The purpose of the design FMEA is to identify potential design risks. Good engineering practices might be considered as a "design control" if you have documented design guidelines. Otherwise, I would have to agree with the guidance that you have been given.
    Mungo likes this.
    5,110
    Agreed! Some folks don't understand that there are assumptions that must be made about other process, as described. It's out of scope to consider the thing being made wrong, or materials not be purchased to specification. The FMEA should be limited to the properties of the design. Trying to legislate, within the DFMEA for other potential failures is scope creep and should be avoided.
    Mungo likes this.
  4. Mungo
    Mungo Member
    Mar 14, 2022
    Hi Miner,
    Thank you for your reply. I know that it doesn't do any harm to include potential failure modes from basic design, although I was unsure of how to describe the boundary of the scope. The 'holes mis-aligned, bolt can't be inserted' potential failure mode implies that the product assembly will be assessed right from the pile of parts. I suppose I should say that this is a system level DFMEA rather than at a component level, and therefore that is why I was assuming that the assembly of the component parts was already accomplished.
    Hi Andy,
    Thank you for your comments; part made not to print or with the wrong material are out of scope for me too, I appreciate you stating this.
    To clarify on aspects such as tolerance analysis of a bolt pattern group, I would expect that it can be assumed that the assembly goes together ok, based on good engineering practice. The assembly is now ready for testing (and simulation prior to and in parallel to testing) and the DFMEA is going to have great influence on the testing regime as higher RPN FMs will need to be sought through rigorous testing. If the second pile of the same parts won't assembly into the second prototype due to a tolerance stack, then is this not more of a PFMEA issue rather than a DFMEA issue?
  5. Miner
    578
    No. Remember, the assumption is that the parts are built to the design intent. In the DFMEA, you take into consideration whether the size and tolerances of the bolt hole pattern are sufficient to allow assembly of the stud pattern under all extremes of that tolerance. I am sure that you have encountered tolerance stack up issues that prevented assembly. These are design issues, not processing issues. Do not assume that good engineering practice is an effective control. I have seen too many design errors to believe that. The greater the product complexity, the greater the likelihood of a design error.
  6. Mungo
    Mungo Member
    Mar 14, 2022
    Would it be fair to say that the hole pattern tolerance is within the component level DFMEA, i.e. FM = 'hole tolerance does not always allow assembly of bolts to 'other' part', and that at the assembly (or system) level DFMEA the bolted joint can be assumed to have assembled appropriately (in order to get the system onto test then it is already assembled)?
    I don't recall including the operation of assembling the system as a test within Current Control. If the hole pattern tolerance meant that the assembly looked ok but during system operation (testing) the skewed bolts tight in the holes due to 'designed' out of position had caused the gasket joint to leak then this is what I feel we are trying to identify. I don't see how or why we need the DFMEA to predict that we can't assembly the pile of parts in the BoM.
    Is there a paragraph in any of the manuals that illustrates the scope of a DFMEA with respect to machine assembly?
    Is there a list of typical failure modes that includes aspects that apply to the machine assembly operation (I want to learn, to be convinced of a different point of view but I don't find references for these aspects)?
    Does a PFMEA include the operations that assemble the component parts into an assembly?
  7. Miner
    578
    A system FMEA should focus on the interfaces and interactions between the systems and subsystems comprising the assembly. A component FMEA typically focuses on a specific component.
    Current controls must be design controls implemented prior to releasing the product for manufacturing. Testing a few random parts for assembly would not be as effective as performing a Monte Carlo simulation on the assembly. A lot depends on the complexity of the system. A simple assembly tolerance stack-up might not need a system FMEA, but a complex electronic system would.
    It is easy to become confused between the different levels of design FMEAs. Engineers will often unconsciously vary the depth of the FMEA as they go. The image below illustrates how this should work, but don't get too concerned if it isn't perfect. Typical failure mode categories include:
    • No function/assembly
    • Intermittent function/assembly
    • Partial function/assembly
    • Over function/assembly
    • Function/assembly degrades over time
    • Unintended function/assembly (i.e., unintended assembly means it can be assembled upside down or backwards)
    Yes, PFMEA includes manufacture, assembly, inspection and test.
    PhilD313 and Mungo like this.
  8. Mungo
    Mungo Member
    Mar 14, 2022
    Hi Miner,
    Thank you for your further guidance. I like the diagram showing the interconnections between FMEAs; this is helping me.
    Do you know of any online training or reference material in this realm of interacting FMEAs?
  9. Miner
    578
    The only document I have seen that covers FMEA to this level of detail is an older Ford Motor Company manual called Failure Mode and Effect Analysis: FMEA Handbook (with Robustness Linkages) published by Ford Design Institute. My copy is version 4.1 copyrighted 2004. Suppliers could obtain copies from Ford until AIAG started publishing their manual. I don't know if it is still available.
  10. Miner
    578
    I found an example, but cannot recall where it is from.
    Mungo likes this.
  11. Mungo
    Mungo Member
    Mar 14, 2022
    Hi Miner,
    That diagram is real high value, thank you so much, I feel like my standpoint is shifting.
    Where it says ‘provide dimensional control’ under ‘upper frame’, do you interpret that as meaning provide the correct frame geometry to work well as a bicycle, (handle bars, seat, crank in good relative positions to perform well as a bicycle) or interpreted as the upper frame needs to be 21.1” long to fit in the gap between the other members where that gap is 21.1”?
    This is where I say that good engineering practice and a ‘design review for drawing approval’ ensures that the member fits the gap. This was my original understanding but we’re getting to the essence of what I wish to understand properly and clearly. I’m a somewhat binary perhaps but once I buy into a set of rules, then I will endeavour to apply them.
  12. Miner
    578
    Look at it this way:
    • If the upper frame is long, the effect on the next higher level system would be a distortion of the geometry of the frame subassembly, or if rigidly fixtured, it may not assemble at all.
    • If the upper frame is short, the effect on the next higher level system would be a distortion of the geometry of the frame subassembly. or if rigidly fixtured, the extra gap might be filled in with weld, possibly weakening the subassembly.
