Determining Melt Flow Range of Product
Discussion in 'Gage R&R and MSA - Measurement Systems Analysis' started by Nikki, May 25, 2016.
  1. Nikki
    Nikki Well-Known Member
    268
    141
    Hello All -
    I have been tasked with determining the average Melt Flow / Molecular Weight measurement for certain compound products.
    I am collecting data by Polymer Grade type, and then formulation. For example:
    Polymer Grade #1
    Polymer Grade #1 with colorants only
    Polymer Grade #1 with colorants and 20% Barium Sulfate
    Polymer Grade #1 with 50% Bismuth Subcarbonate
    Now for each category listed above - there may be 25 formulations that fall into that category. Because there is a slight variance on the actual ingredients going into the compound, the Melt Flow Range is somewhat different for each individual formulation.
    While one formula gives me a range of 16 - 21 g/10, another may give me 26 - 50.
    What is the best way to determine the average range? Do I just talley them all up and then choose the smallest and largest result and call that the range? Or is there a more accurate method I am just not seeing?
    Thank you,
    Nikki
  2. Eric Twiname
    329
    232
    How precise is needed?
    From one point of view, "average" is meaningless...it is a different formula, therefore it is a different product, there for averaging it with another product has no purpose.
    From another point of view, having an average for a family of products gives a chance to screen through your products more easily.
    Which is the target? What you use the final result to accomplish may steer which calculation is most appropriate
    MW is a fairly rough number to begin with...
  3. Nikki
    268
    141
    No target - this is merely for a reference for Sales as customer's call them up and say they want a Polymer with a melt index of XXX g/10.
    The information I am putting together will be the average range for each family of products as you put it.
    What I am seeing - is that here and there are outliers.
    So I took an excel spreadsheet and high-lighted the range of each formula that I found.
    I think the way I want to do it, is to use a range that at least 3 of the formulations fall into, high-lighted below.
    Does this make sense?
    If I were to use this method, the range for this one would be 29 - 42 g/10 - and it would exclude those that seem to be out of the ordinary. upload_2016-5-25_15-6-48.png
  4. Eric Twiname
    329
    232
    Whatever method you use...make sure that the folks using the info (salespeople) agree with it.
    If it is a family of similar formulation, you might choose to take the median of each range, then break into families of similar median.
    Sales literature is not a spec...but you might have trouble getting a customer to agree with that statement.
    Make sure the range you set covers the normal variation of the product.
    In your row#6, if you tell me that the range is 29-42, then ship me 27...we would have a problem...
    Nikki likes this.
  5. Nikki
    268
    141
    Thanks Eric. This is going to be more of a reference for Sales - so that they know if the customer asks for a product with MFI range of X g/10 - they can explain to the customer almost immediately the "general" MFI range.
    Melt Flow specifications are set once we have produced 3 to 5 lots - to come up with a specific range for that exact formulation.
  6. Eric Twiname
    329
    232
    Lol...sounds good. But you've gotta know it won't be used that way...
    Scenario:
    Customer: I want a flow range of about 30
    Salesman: Any of these products meet that, here is the spec from our QC department (holds out the sheet of "general" MFI range you gave them)
    Customer: I need the spec tighter than that
    Salesman: No problem, we can do that...when will you order?
    ...and downhill it goes...
    If it is going outside the four walls...make it tight, make it right.
    Nikki likes this.
  7. Chris Brockway
    Chris Brockway Member
    Aug 20, 2015
    Sydney Australia
    And our regional Quality Manager has instituted a sign-off system for spec changes to address this very problem. For a spec change to occur, there must be agreement from Technical, Operations and Commercial. Unfortunately this doesn't address the millstones hanging around our necks from silly decisions in the past.
