Dataloger calibration
Discussion in 'ISO 17025 - Calibration and Test Laboratories' started by Carlos Samaniego, Jun 14, 2016.
  1. Carlos Samaniego
    Carlos Samaniego New Member
    Oct 28, 2015
    At the AB assessment to my calibration lab, the auditor settled a non conformity due to the data loggers we use to measure environmental conditions (temperature and humidity) were calibrated for an external laboratory accredited to calibrate thermometers and hygrometers but its accreditation scope does not include data loggers. We discussed with the auditor that there is no difference between to calibrate a thermometer and a data logger for a calibration lab, but the auditor did not accepted reasons.
    What is your opinion folks?
    I have searched for a lab accredited to calibrate data loggers and I have not find any neither in USA nor even in some european countries.
  2. equilibrium
    equilibrium Member
    Aug 10, 2015
    32
    Have you tried contacting the manufacturer of the data logger? That's usually a good starting point.
  3. Englishman Abroad
    Englishman Abroad Member
    Mar 29, 2016
    25
    Carlos,
    I assume that the temperature is measured with some sort of thermocouple and then (the voltage created) recorded as a temperature by the data logger.
    Can your current calibration lab calibrate the whole system (thermocouple and data logger) together, rather than separately?
  4. Carlos Samaniego
    Oct 28, 2015
  5. Carlos Samaniego
    Oct 28, 2015
    Te calibration certificate presents results for the system as a whole: as the error between a reference value and the data logger indication and similar for the humidity.
  6. equilibrium
    equilibrium Member
    Aug 10, 2015
    32
    My understanding of data loggers is admittedly somewhat limited, but I don't personally see the need to specifically list data them in the accreditation scope. By itself, isn't the data logger basically a box with numbers? Again, this is just my opinion.
    I did happen to find Control Solutions, Inc.
    This is NOT an endorsement as I have never done business with them, but as they appear to be accredited they could probably speak to this point.
    I hope someone finds this helpful.
