Correcting Audit Findings
Discussion in 'ISO 13485 and ISO 14969 – Medical Devices QMS' started by Lindy, Jan 10, 2018.
  1. Lindy
    Lindy Member
    Jan 10, 2018
    Hello - new to this forum.
    I have a question regarding internal audit findings and correcting those findings.
    Is the auditor who identified the audit finding allowed to perform any of the actions to correct the finding?
    I am the internal auditor at my company and my boss has me perform the corrections to many of the audit findings, which includes rewriting procedures. I'm nervous that this will muddy the waters of remaining unbiased and separate from the department that I'm auditing. Although I'm more than happy to assist the department/individuals involved in correcting these findings, I don't feel right having the internal auditor who published the report as the person in charge of the action item to correct the finding.
    Would I get in trouble if an outside firm were to audit my company and see that I performed actions to correct the findings, or is it OK to do this?
    Thank you for any insight you may have.
  2. Golfman25
    How big is your company? With a small company, you may tend to wear many hats. In other cases, you may be a good resource to help. So, while I wouldn't put you "in charge" using you as a resource could be a positive. There is nothing worse than a "hit and run" -- auditor finds something and then disappears. Whether that will pass an outside audit would depend I suppose.
    Hi Lindy! Welcome!
    So, two things: As long as you aren't doing these corrections actually during the audit, then yes, fine. Also, if you are doing editorial changes to documents which aren't your process(es) and they are being brought up to date with the actual practices, then that's fine too. The key thing here is that as long as it's not YOUR work you are auditing, that's best - unless you can show the audit process has ensured objectivity (factual) and there's no bias (you looked at things you did, maybe 3 - 6 months ago perhaps).
    If the audit findings require a different process, then it's best NOT to be involved. BTW, what position is your boss?
  4. Lindy
    Lindy Member
    Jan 10, 2018
    Thank you all for your responses!
    My company is stretched a little thin regarding available resources, so it isn't usual for various employees to be asked to help out in other areas. I don't like to be the grenade-throwing type auditor who takes off, but I also need to figure out where to draw the line of helping a finding get corrected, and doing the corrections myself.
    My boss in the VP of Quality and Regulatory, so there isn't anyone else I could raise my concerns to. I'm glad I found this forum to be able to get an outside opinion!
  5. Serious Man
    Serious Man Active Member
    Oct 24, 2017
    79
    28
    Auditor's job is evaluating adequacy of determined root cause, proposed corrections and corrective actions.
    Doing it personally exclude possibility of auditing it in future. So after some time maybe there will be almost nothing to audit.
    When company is small, it should outsource internal audit process, if resources available to make corrections are limited.
  6. Golfman25
    So it should cost small companies double -- pay once for an internal audit and once for a third party?
  7. Serious Man
    Oct 24, 2017
    79
    28
    If someone does not take internal auditing serious, can save money and continue fake job.
  8. Golfman25
    Actually in smaller companies internal auditing is a waste of time. Generally, in small companies true non-conformances make themselves readily apparent -- there is no place to hide. But heck, if it give everyone a warm fuzzy feeling inside, go for it.
    Only if you see audits through the eyes of the CB - too many internal audits are done emulating the CB process. I can show you much more effective internal audits, I've done for small companies which were worth a ton of money...
  10. Golfman25
    I wouldn't disagree with that. Please share. But would they get past a CB auditor? My experience is they get really uncomfortable with something different.
    Happily! And FWIW, I also understand the reaction with CB auditors. I also have had plaudits from them (through my clients' feedback) about my approach...
    I really believe we should stop being ruled by these lack luster CB auditors. I heard yet another trainwreck story about an IATF auditor today...
  12. normzone
    normzone Well-Known Member
    137
    78
    Yes, and I'd like to stop tectonic drift also.
    One audit will accept an overview with a summary and call it effective, another will not and the only way to counter that is to use the checklist full element review model.
    Damned if we do and damned if we don't
  13. Andy Nichols
    inconsistency I understand. Why oh why do you allow someone who has little/no experience of your business, who spends only one or two days in your facility dictate HOW you run your business? Ask someone at a Business School what they'd say to that as a model of business operations...
  14. Jennifer Kirley
    I am also bothered by inconsistency in CB auditors. I often audit a system with previous NCs having been accepted with the barest minimum of corrective action plans, whereas we are required through accreditation to 17021:2015 to:
    <<9.4.9 Cause analysis of nonconformities
    The certification body shall require the client to analyse the cause and describe the specific correction
    and corrective actions taken, or planned to be taken, to eliminate detected nonconformities, within a
    defined time.
    9.4.10 Effectiveness of corrections and corrective actions
    The certification body shall review the corrections, identified causes and corrective actions submitted
    by the client to determine if these are acceptable. The certification body shall verify the effectiveness
    of any correction and corrective actions taken. The evidence obtained to support the resolution
    of nonconformities shall be recorded.>>
    CBs have procedures, but application is as wide as the river Nile and there is no successful program to "calibrate" auditors that I've seen. But don't blame it on the auditor; the documentation is supposed to go through a review and it is at that point that management can exert its influence.
  15. Jennifer Kirley
    I have rarely seen internal audits that were worth the paper they were printed on. 9.2.1 says internal audits will be conducted to determine if the QMS is (b) effectively implemented and maintained. This could be from a number of reasons, but the truth is that value-added auditing (while verifying conformance with the standard at the same time) is not easy. Persons who are thrown into those roles too often do not understand how to audit for value or discover underlying issues.
    Corrective actions are worse, in many cases repeating the symptom and failing to address cause(s) that could enable the problem to repeat or occur elsewhere (10.2.1(b).
    The auditor in question isn't here to defend himself, so it is easy to beat up on him. We do have the right to require specific types of responses - and rightfully so. That said, I do ask my clients to produce thoughtful, meaningful corrective actions that will, we dare to hope, avoid a recurrence because repeating nonconformities in 3rd party audits get escalated almost by default. I suppose someone out there is complaining about me too. :)
  16. Golfman25
    The problem is the tool CBs use is a hammer. Every problem isn't a nail. Having a full 8d type analysis isn't always necessary.
  17. Jennifer Kirley
    What standard are you being audited to? I audit to 5 standards and have not once seen an 8D required for corrective action.
  18. Golfman25
    TS/IATF 16949. Simple corrections of oops isn't enough according to our cb.
  19. Andy Nichols
    The "iceberg" principle...
  20. Golfman25
    Maybe, maybe not. Everything isn't always applicable everywhere. Especially when dealing with nit pic "findings."
