control limits
Discussion in 'SPC - Statistical Process Control' started by samy aly, Dec 26, 2023.
  1. samy aly
    samy aly Member
    Dec 26, 2023
    how can I determine the control limits (upper and lower limits)
    5,117
    Welcome to QFO. One of our SPC wizards will be along to assist you shortly…
    samy aly likes this.
  3. Bev D
    608
    665
    What kind of data are you working with?
    Do you have any training in SPC?
  4. samy aly
    samy aly Member
    Dec 26, 2023
    continuous data , length , width , fragmentation of glass , etc
    yes I have training in SPC
  5. Bev D
    608
    665
    If you have had training then you know you need to use the formulas for continuous data. The exact formula is dependent on the subgroup size you are using.
    UCL = Xbar_bar +A2*R_bar and the LCL = Xbar_bar - A2*R_bar.
    X_bar_bar is the grand mean (average of the subgroup averages)
    R_bar is the average of the subgroup ranges (max value - Min value)
    A2 is the factor that is dependent on the subgroup size. A2 can be found in any SPC factor table and is limited to n>2 and n<26. If your subgroup size is larger than that you should use the formulas for subgroup standard deviation instead of the subgroup range.
    Don’t forget the Range chart: UCL = D4*Rbar and LCL = D3*R_bar
    These are simple formulas taught in any legitimate SPC training. They are of course just the tip of a very large iceberg. Is there something that you are still not clear about?
    Miner likes this.
  6. samy aly
    samy aly Member
    Dec 26, 2023
    thanx
