Competency Requirement Question
Discussion in 'ISO 9001:2015 - Quality Management Systems' started by QualityLady414, Nov 29, 2023.
  1. QualityLady414
    QualityLady414 New Member
    Nov 20, 2023
    Hello, I have a question regarding this clause in ISO 9001:2015. I just started working for a company and they have completed competency forms for each employee. My concern is we do not have any training records per manager/department. Would it be a nonconformance in an audit only having just competency records?
  2. Golfman25
    821
    405
    Simply stated training does not equal competency. So "training" records are not required.
    7.2(b) provides three general ways to achieve competency -- education, training, or experience. (d) requires documented evidence of competence. So if your company evaluates each employees' competence for the job they are assigned, and maintains a record of that evaluation, you're good to go. That competency evaluation is more important, imo.
    tony s and QualityLady414 like this.
    Welcome. For clarification’s sake, what “audit” are you asking about? Also, what does your own process say about competency, training etc?
  4. QualityLady414
    Nov 20, 2023
    ISO 9001:2015, recertification. Currently, for our process, we only require competency records. However, when I was with a previous employer we received a nonconformance for not having both training and competence records as the auditor said that we needed evidence of both. I agree, competency evaluation is important/
  5. Golfman25
    821
    405
    Your last auditor was wrong and probably applied the lazy auditor standard. Seeing training records is a check the box exercise.
    QualityLady414 likes this.
    To be honest with you, you could get another non-conformity, because there are plenty of poor auditors out there. However, you are correct (unless your QMS says different) the requirement is for competency. At least you have the right to appeal a non-conformity.
  7. tony s
    What are competency records?
    “Evidence of competence”, as per clause 7.2d, means proof that a person has the ability to apply his/her knowledge and skills in achieving the intended results (see definition of competence in ISO 9000:2015). Training certificates, school diplomas, even list of trainings attended can only provide evidence of acquisition of the knowledge and skills – not their application.
    Records kept on employee job performance assessment to determine whether they have achieved the expected results (e.g., objectives, targets, KRAs, KPIs, outputs, etc.) would fit as “competency records”. Is this what you are referring to? If so, then, as @Golfman25 said, you’re good to go.
    True, however, that doesn’t mean the auditor is correct. Training - especially a record of attendance at a class - doesn’t mean the training even was effective nor does the actual event confer competency on a person.
    A non-conformance for lack of a training record would be cause to reject it.
    CLEMENT OHANGA likes this.
