Can factors be significant if there is a lack of fit and weak R²?
Discussion in 'DOE - Design of Experiments' started by Rockychano, May 20, 2019.
  1. Rockychano
    Rockychano New Member
    May 20, 2019
    Hello everybody,
    after my ANOVA the R² of the model is really bad (R² = 0,1743) and it has a significant lack of fit (lack of fit = 0,0096). I used 8 factors but only one was selected as significant.
    1.) The lack of fit tells me, that the model needs to be extended by another term (quadratic term, 2-way-interaction or a completely new term). Is that right?
    2.) One factor was identified as highly significant (p = 0,012). Is it ok to trust this result, although the model (lack of fit, R²) is really bad?
    Thank you
    Welcome to QFO.
    Your assessment is essentially correct. Your one factor that was identified as significant probably is significant. The model, however, is not a good model. As you speculated, there are a number of reasons for this such as missing factors, interactions, quadratic terms, or a covariate. Also look at your data to see whether you have a few data points with large residuals. Investigate and validate these as correct. Adding the correct missing factors should improve your R². If you address the lack of fit and find that you still have a poor R², you then need to investigate the sources of your experimental error starting with the measurement system.
    Rockychano and Bev D like this.
  3. Bev D
    What Miner said. Plus remember that the R squared value is essentially a measure of the amount variation due to the factor(s) being evaluated. In other words a low R square means that most of the variation is driven by one or more factors that were present in the study but not tested for. Also a very important thing that is too often overlooked is that statististical significance (no matter how low the p value is) does not mean practical importance. In other words the p value does not tel you if the identified factor is the dominant or controlling factor. To have a useful model you must have identified the controlling and occasionally strongly contributing factors.
    Rockychano and Miner like this.
  4. Miner
    Some experiments can best be described per the following quote by Andrew Gelman:
    "My best analogy is that they are trying to use a bathroom scale to weigh a feather—and the feather is resting loosely in the pouch of a kangaroo that is vigorously jumping up and down." Kangaroo.png
    Rockychano, Bev D and Andy Nichols like this.
