Calibration of Mylars (?)
Discussion in 'Gage Calibration and Uncertainty' started by Tom Waite, Oct 19, 2015.
  1. Tom Waite
    Tom Waite Member
    45
    33
    Grand Rapids Michigan Area
    Define calibration?
    Reason for question: Customer print says CAD data is master data for part size. Mylar check fixture is made from CAD data. Mylar is the nominal of the part perimeter with the upper and lower tolerance drawn. Lay the part on the Mylar and make sure the perimeter is in between the lines.
    Told mylars have to be calibrated annually. I have always understood calibration to mean adjustments can be made. No adjustments can be made to a mylar visual cheek sheet. It's replace when needed based on visually checking line quality.
    Verification is more what is needed and that is to make sure the mylar lines are still readable. Semantics, but verification is much quicker and less expensive than calibration.
    Verification would be visual check of revision and line quality on the mylar.
    Calibration is the measurement of each part characteristic on the mylar with another calibrated method (CMM - Calibrated steel rule, etc.).
    Input?
    4,422
    2,226
    I've read some crazy things in my time, but this might, just might take the biscuit. Calibrating/verification of mylars? <SMH>
    Calibration is the science of knowing how far a device is (off) a known measurement value - nothing to do with adjustment.
    Tom Waite likes this.
  3. Jennifer Kirley
    993
    678
    I've often confronted the question of calibrating (ISO 9001 says calibrate/verify) instruments for which deviation can only be a result of wear within a decent environment. Examples are steel rules, visuals, and steel gage blocks. Polyethylene Terephthalate (trade name Mylar) is so much more stable than paper that a person who insists you must recheck a visual made of Mylar against a calibrated standard every year is just treading unthinkingly down a well-worn path. It might help to establish a frequency to go over these instruments and see if they need replacing, based on how long they've been lasting and how critical is their continued readiness. Being expected to hold to a yearly frequency is not, in my view, good calibration practice.
  4. equilibrium
    equilibrium Member
    Aug 10, 2015
    32
    I would agree that mylar tends to be very durable and I definitely agree that in the case described it would at most need a visual check for visibility and condition. Technically I would consider this a verification and not a calibration. It would be a good time to take advantage of interval extensions if you utilize them, since the likelihood of a failure is very small. I would have no problem extending a mylar overlay out to three or even five years.
    As was already mentioned, adjustment is totally separate from calibration. Calibration is the comparison of one value to another by means of a traceable standard. The "known" value of a standard is technically a range of values, due to uncertainty. Calibration produces a numeric value.
    Verification is concerned with attributes (i.e. is the color correct, what types of defects are present.) There may be accept/reject criteria but these are not generally based on a numeric value. This also tends to be somewhat subjective.
    Jennifer's points are fair. I feel most yearly calibration frequencies are based on convenience rather than need. I would however not lump gage blocks in with steel rules or visuals. For dimensional metrology, calibrated gage blocks are a huge part of everything we do. These are one of our traceable standards.
    4,422
    2,226
    ^^^^ Excellent post! :)
  6. Tom Waite
    Tom Waite Member
    45
    33
    I get calibration is determining the value as compared to the desired value, but is reacting to that value if required not part of calibration?
    I understand calibration is the determination of the value of measurement as compared to the intended result. I am going to assume you would say it would then kick into corrective action for the adjustment, and then back to calibration to confirm. I was once told you can't calibrate something that cannot be adjusted? It's just verification if it cannot be adjusted. Is that not accurate? Is it semantics?
    4,422
    2,226
    Whomever told you that, doesn't understand it! I heard the same thing for years while I worked in multiple manufacturing plants across the USA. For example, a plain plug gauge can be calibrated. It cannot, however, be adjusted if found outside of the size/geometry required. It can be ground to another size or reclassified but there's no adjustment. Same for gauge blocks etc.
    The work of calibration is, just like ISO/IEC 17025 says about the lab's responsibility, to report the results (only). What should be done, following calibration isn't part of the calibration process...
  8. BradM
    BradM Moderator Staff Member
    362
    283
    Arlington, TX
    The thing is... words and phrases can mean different things to different people; and sometimes they both could be correct. :) Calibration is one of them.
    That's why I think it's really important to have calibration defined, and make sure everyone is referring to it consistently.
    For example, the VIM (2008) is a good reference to use for standardizing terms. The term calibration is defined pretty much like Andy/Jennifer defined above. As a matter of fact, they add this note:
    "NOTE 2 Calibration should not be confused with adjustment of a measuring system... ".
    Thus, you could define calibration, maintenance, and performance check, so that everyone (including your customers) understand what is being accomplished.
    Bob Doering, Bev D and Andy Nichols like this.
    4,422
    2,226
    True, Brad. Wouldn't it be great if people would use such terminology in the fullest understanding? Sadly, the word "calibration" is so abused - across all manner of industries (even my HP printer is "calibrated", apparently, which is so odd because HP got started making measuring equipment and should know better!) that we may just have to concede to a lost cause...
    BradM likes this.
  10. Eric Twiname
    329
    232
    Outside of the semantics (I was wondering how long it would be before the Calibration vs Verification dialog would begin again)
    Who told you?
    If it was the customer...it may be easiest/cheapest to simply comply. Think about all of the silly things you do to please customers and just add this one to the pile.
    This yearly check costs way less than the dinner your salesperson takes the customer out for.
    If it was a non-customer auditor there are three ways to go:
    1. Comply (sometimes it's easier/cheaper to go along with unreasonable demands than to fight them)
    2. "Sort-of comply"...by establishing a calibration period of 10 years and stating why you think that time frame is adequate, but including also a "replace if damaged"
    3. fight the fight
    I've rarely found it the most profitable road to "fight the fight"...occasionally so, but rarely.
    10 minutes/year of doing something I know is ridiculous is less annoying than 20hrs of argument with unknown outcome.
    In the big picture...10minutes a year costs less than an ongoing debate.
    None of us have the time to fight for everything we feel is right and good, or against everything we think is wrong or ineffective....more's the pity.
    4,422
    2,226
    Excellent comments, Eric. It would be interesting to know what the customer's "spend" is - sometimes, telling them to "take a hike"is OK too, if they demand certain futile activities like this. It's been my experience that an SQA who "requires" things from a supplier, without formal agreement, is often overridden by Purchasing for fear of a disruption...
  12. Bev D
    518
    565
    All great replies.
    Having been in aerospace and defense where part designs are 30-50 years old and involve a lot of features that are very difficult to measure (curved lines or parts that bend/move when measured, Mylars were very common. They were calibrated. And I agree that they need to be calibrated (using the official definition) and their condition should be checked at every use for wear of the lines, tears to the Mylar, etc. We routinely do this for other gauges that can be dropped or have other damage done to them.
    However its important to understand that calibration of a Mylar is not a simple or cheap thing to do: think about it, if you have a Mylar, it's because its tough to measure the part, so measuring the Mylar is also tough. We had hundreds of them. So while I would agree that sometimes the simple thing is to comply to the Customers 'unreasonable' request for annual calibration, financially it wouldn't make sense in many industries. Every standard has allowances for determining the calibration cycle based on science. Unless I only had a couple of Mylars I would discuss a calibration cycle based on science - and data if I had to get it showing that Mylars don't 'degrade'.
    equilibrium likes this.
  13. Eric Twiname
    329
    232
    FWIW, the few Mylars we use here are used flat (as opposed to being wrapped around a part).
    It's pretty quick and simple to throw them on a CMM and verify...thus my 10minutes comments.
    I know others can use mylars for much more demanding operations where they may not be nearly as easy to measure...
  14. equilibrium
    equilibrium Member
    Aug 10, 2015
    32
    I have only seen mylars used as overlays for an optical comparator, or for basic dimensional checks as Tom described. What Bev describes is a very different situation. That's an interesting usage I wouldn't have thought of.
    I totally agree with that statement; we calibrate to collect data to show the stability of our M&TE, regardless of whether it's a mylar with complicated dimensions or any other sort of instrument.
  15. Andy Nichols
    4,422
    2,226
    Ha! That reminds me of that myth about using manufacturer's recommended recall/cal cycles... :rolleyes:
  16. Bev D
    518
    565
  17. James
    James Active Member
    Aug 31, 2015
    50
    Oklahoma
    I used to work in Quality in an Aerospace sheet metal facility and we used mylars almost exclusively. Most of what was being made used tooling that was decades old. This shop also did not have digital opportunities like a CMM. So contours and such were fun.
  18. Tom Waite
    Tom Waite Member
    45
    33
    Thanks for the input everyone! I am sure that if the topic comes up again I will be in a better position to debate this need. Come to find out this may have been a self imposed action several years ago before my time, to just end the debate with the auditor, so the organization said we would do this just to move on.
    Not my style, so I will be changing this - if it does not add value, or is not required to be done (regardless of adding value) then we are not going to do it just to avoid a discussion with the auditor.
    Atul Khandekar and Andy Nichols like this.
  19. Bob Doering
    Bob Doering Member
    37
    26
    In order to validate and verify a mylar, I always had a 1" by 1" box place on it as a standard part of the design. Then, measuring that box with an appropriate measurement system would assure the stability of the mylar has not been compromised, and the check was fairly painless. It was particularly handy when printing them out to assure they were to scale. It was also a lot easier than measuring features.
  20. Andy Nichols
    4,422
    2,226
    Coming from several years of copier development, you'd best be sure the copier/printer doesn't do some kind of image shifting... Even a 1" square on the mylar may not actually give you the accuracy you think you're getting - at the margins...
