Area of Concern - Closing effectiveness
Discussion in 'ISO 9001:2008 - Quality Management Systems' started by Padym, Nov 23, 2015.
  1. Padym
    Padym Active Member
    Oct 19, 2015
    55
    Hi All,
    In our last external Audit 9001:2008 auditor noticed one area of concern. Internally we are discussing, on same and tracking via internal ticket. I want to ask how the auditor will assess the effectiveness of the corrective action as still there are discussion around it.
    Can you give us some details? I'm uncertain what the subject is. What corrective action subject are you discussing?
  3. Qualmx
    If you mean a nc ,then,from here a ca is needed.
    In order to determine if the effectiveness of the action was successful, it is needed the evidence.
    And the criteria for the closeout, normally is defined by the responsible of the nc.
    Hope this help
  4. Chris Glover
    Chris Glover Active Member
    Aug 7, 2015
    54
    32
    We do two audits on non-conformances. The first to assure the Counter-measure determined during the Corrective Action process was implemented. This audit is done 30 days after the CA is closed. The second audit is done at 60 days; this audit is to determine if the counter-measure was effective (also checks to assure C/M is STILL in place.
    We also do, as part of our process audit program, follow-up audits 120-180 days later.
  5. MCW8888
    Even if there is no need for a procedure for CA, perhaps you can specify in your CA form that second audit done in 60 days is the audit of effectiveness.
    No need for a procedure? I don't understand your comment. Also, isn't the point of CA that it's specific to the circumstance reported? Why would 60 days be appropriate every time? For an internal audit it should be planned with management, not force to fit some arbitrary number of days...
  7. MCW8888
    I understand. I was just following the person's note. We have a CAR form that specifies 30 days for first verification of effectiveness, then there is a second verification, etc.. I guess these are no longer necessary.
  8. Chris Glover
    Aug 7, 2015
    54
    32
    60 days has been determined by management...even if it is arbitrary..that is what we have been directed to do...
    We also do other follow-up audits based on other criteria
  9. Qualmx
    Really there is not a rule,it depends on the nc.
    I dont consider a fixed frame to do a follow-up of Ca.
    instead Define the criteria for the closeout ,once I have evaluated the efectiveness.
    For example one nc found in an equipment.my criteria for the closeout it is to work at full capacity for one month,or one nc in control of documents found in an internal audit,well, for me ,I define that efectiveness is ok if in two consecutive internal audits the problem is solved,then I close the ca.
    Regards.
    Kamal and Andy Nichols like this.
  10. Padym
    Padym Active Member
    Oct 19, 2015
    55
    Thanks of all you for your inputs. This is not a NC but an Area of Concern, which may lead to NC in next surveillance audit if no proper action taken to analyze, closeout. The concern is registered in our internal tracking system and still in the discussion.
