Application development & Tests (not R&D): Which sub-clause under 8 - "Operations"?
Discussion in 'ISO 9001:2015 - Quality Management Systems' started by Johan Lantz, Feb 1, 2017.
  1. Johan Lantz
    Johan Lantz New Member
    Dec 7, 2016
    Can someone tell me under which sub section "Application development" should be connected to under 8 - "Operations"? We only runt tests and application development and not any R&D.
    Regards
    Johan
    Good question! Is this your product or someone else's? Can your organization change the target specification or must the customer approve?
  3. Johan Lantz
    Dec 7, 2016
    Thanks for quick feedback! It's our own products and the target spec can be changed by us after customer approvement.
    IMHO most (if not all) of the sub-clauses under 8 Operation are applicable. If you have the following processes for application development, the relevant requirements within the indicated sub-clauses should be met:
    1. Establishing the application development plan - 8.1 is applicable;
    2. Requirement analysis - 8.2 is applicable;
    3. Specification and software architecture design and development for the application (i.e. product) - 8.3 is applicable;
    4. if you're using subcontractors or have to procure programming software - 8.4 is applicable;
    5. Implementation and documentation of the application - 8.5 is applicable;
    6. Application testing - 8.6 is applicable;
    7. Debugging - 8.7 is applicable.
