Advice on Commercial CAPA databases?
Discussion in '5S, 5Why, 8D, TRIZ, SIPOC, RCA, Shainin Methods...' started by Sara Nova, Sep 15, 2015.
  1. Sara Nova
    Sara Nova Member
    Sep 15, 2015
    I am doing some research for my company on CAPA databases. We are working on implementing a QMS and want to avoid tracking Corrective and Preventive Actions (CAPA) through an excel spreadsheet. Can anyone suggest some good products to look at? So far Intelex and MasterControl have come up through Google U. Has anyone used Microsoft Access? Other suggestions?
  2. Jennifer Kirley
    I have clients who use Action Tracker. I'm not sure if this is is the product. Then there is Mantis, which I think is still free - it started out as a bug tracker for software engineers but might suit your needs.
    Sara Nova and Pancho like this.
  3. Pancho
    Pancho Active Member
    76
    84
    Cypress, Texas, USA
    We use Bugzilla. It's also bug tracking software. Free and open source.
    Sara Nova likes this.
  4. Gert Sørensen
    Gert Sørensen Member
    Denmark, Copenhagen area
    I am not in any way affiliated but take a look at ETQ, they have a SaaS solution that is affordable and very, very nice.
  5. PaulJSmith
    PaulJSmith Well-Known Member
    107
    113
    Midwestern USA (STL area)
  6. Jim Hagenbaugh
    Jim Hagenbaugh Member
    Aug 4, 2015
    26
    24
    VA
    I have used The Lean Machine as a low cost option . No affiliation other than user
  7. Sara Nova
    Sara Nova Member
    Sep 15, 2015
    Thanks everyone!!
  8. Sara Nova
    Sara Nova Member
    Sep 15, 2015
    Jennifer - is Action Tracker made by Sirota? http://www.sirota.com/action-tracker™-tool
  9. Jennifer Kirley
    Yes that's the one I was looking at. I'm not sure if that's the one my client was using though.
    I have no affiliation with Sirota.
  10. MCW8888
    We have our own internal CAPA database that's managed by Corporate internally. All internal and external nonconformance are entered in this database. I hope you will find these other software beneficial to use.
  11. Sara Nova
    Sara Nova Member
    Sep 15, 2015
    Jennifer I am checking out Mantis. Could be a good option if the default fields can be configured. For example, change "reproducibility" to "department" or something like that. Do you know if this is possible?
  12. Jennifer Kirley
    I would certainly check out Mantis. I do not know what it would take to change category/function titles. Pancho uses Bugzilla, another open source bug tracking software. Maybe Pancho can describe how much was needed to repurpose that software for CA/PA?
    DavidD likes this.
  13. Pancho
    76
    84
    Cypress, Texas, USA
    Bugzilla can be configured without too much trouble. We re-purposed some fields and added others: we use the "Product" field for "Process", and we added fields for "root cause" and "corrective action". Lists of field values can be customized. This lets you define the different processes (and other variables), and then users pick out the one from a pop-up menu rather than typing the name. You can also add lists of users who get automatic emails whenever there are updates to any CAR that meets certain criteria. Automatic notifications and custom reports of all kinds can be easily set. The documentation is quite decent for free software.
    All of the above we did without programming. You do need to be comfortable installing software on your server and fiddling with the server OS a bit to get the whole thing going the first time and every few months when enough changes have accumulated that you want to upgrade your site.
    Sara Nova and Atul Khandekar like this.
  14. Sara Nova
    Sara Nova Member
    Sep 15, 2015
    Just to follow up on this: my client ultimately went with a little-known software called Cube DMS. You can check it out at http://www.cubedatamanagement.com. It's easy to set up and configure, and at $8/user/month, very affordable. I have 3 clients on this software now, and all are happy with it. I have also seen a lot of companies create a database in Sharepoint to log CAPAs.
  15. Nick1
    Nick1 Member
    Jan 27, 2016
    49
    21
    After years of struggling with this issue, we developed an online Q(HSE) management system to amongst others, track and log CAPA's including root cause, analytics on CAPAs and reminders on the actions. The integrated solution allows you to directly link CAPA's to other parts of your Q(HSE) management system. This setup prevent it from being a stand alone activity. You can find more information on www.qooling.com
    Feel free to contact me.
    nick@qooling.com
    (Full disclosure) I am one of the co-founders
  16. ccoles3
    ccoles3 New Member
    Apr 18, 2024
    Some years ago, we started using this 8D webpage. I don't think it costs us anything and it has got us through some audits. We are an aerospace supplier. I am a basic engineer. Here is the link to the site: https://www.adaptivebms.com/CAPA-Software/
    Before that, we used SharePoint, but it was a bit clunky. Before that, we had a person employed to collect and deliver corrective action requests around the offices on 8D forms. This worked well. Every morning, all the 8D request forms would be gathered up and reviewed by the Ops manager, and then each form would be dished out for action.
    Chris Coles and Andy Nichols like this.
  17. Chris Coles
    Chris Coles New Member
    Jul 2, 2024
    Thank you, the CAPA Manager software recommendation is great!
