Acceptance sampling for Raw Material Receving
Discussion in 'ISO 9001:2015 - Quality Management Systems' started by Manish Sawant, Mar 28, 2016.
  1. Manish Sawant
    Manish Sawant Member
    Mar 28, 2016
    15
    Hello, Friends,
    I am looking for your guidance in developing an acceptance sampling plan. I am confused and just want o make sure I make correct decision.
    We are a door assembly and distribution company and we get our raw materials mainly from sole vendors in most cases. I want to make an ASP for inspecting the pallet of Doors Slabs (ASP for attributes) that we receive since the performance of our vendors has not been to the expected standards. The problem is that we receive really small-finite lots of the sizes that is not consistent and vary from as small as 30 to 500. According to Z1.4, for eg., I get sample size of 8 and 32 for 30 and 250 doors respectively with an acceptance # 0 and 1 resp. (AQL= 1.5%). Also, We do not yet have any agreement with the vendors for sampling plans and thus do not know their process capabilities. So, why don't many recommend to have an ASP based on consumers acceptable RQL?
    1. Is it a common practice to develop an ASP assuming AQL without the consent of Vendors?
    2. Or should we form it based on our acceptable RQL?
    3. For such finite sizes, where Hypergeometric distribution is applicable, the sample size increases even more for the same acceptance #. Is it fine to stick with Binomial distribution?
    4. How do we help our vendors use SPC to improve their process capabilities, quality of products?
    5. What is the good criteria to decide if we want to have a Zero acceptance sampling plan?
    I am aware the message is really big to read and so I apologize in advance, but, I just wanted to make sure our exact situation is known.. Please reply. Thanks.
    Manish Sawant.
    Graduate Student and Intern.
    Industrial Engineering and Management.
    North Dakota State University
    Fargo, ND.
    7017810405
  2. QMSmaster
    QMSmaster Active Member
    Dec 29, 2015
    I would just use a 0 accept plan. It allows you to have the same protection with smaller samples. Over the last 20 years all of my past employers have abandoned regular incoming acceptance sampling and adopted a 0 Defect policy with suppliers. All would sample inspect the first few shipments and then go dock-to-stock. Supplier quality efforts and expenditures were diverted from incoming inspection to proactive Supplier Development, PPAP, auditing, etc.
    NOTE: I am not an acceptance sampling expert. just an experienced practitioner.
  3. Qualmx
    443
    58
    Manish
    In iso 9001 , a filter that could be usefil,it is evaluation of suppliers.
    Once you have verified they comply with your needs, you select those in compliance and you may start buying their products with certain confidence,avoiding to make hard inspection to them.
    Additionally you could perform audits to those suppliers pushing them to improve their quality.
    Regards
  4. Vthouta
    Vthouta Member
    Dec 20, 2015
    We are a door assembly and distribution company and we get our raw materials mainly from sole vendors in most cases. I want to make an ASP for inspecting the pallet of Doors Slabs (ASP for attributes) that we receive since the performance of our vendors has not been to the expected standards. The problem is that we receive really small-finite lots of the sizes that is not consistent and vary from as small as 30 to 500. (The variable sizes doesn't affect the sampling plan)
    A: ANSI/ASQ Z1.4 is the classic plan, evolved from MIL-STD-105. This could be used to any commodity codes as part of the decision making tool during receiving inspection.
    A: My suggestion is to follow the industry standard and you could explain the basis of rejection and moving forward how their products are evaluated.
    3. For such finite sizes, where Hypergeometric distribution is applicable, the sample size increases even more for the same acceptance #. Is it fine to stick with Binomial distribution?A: Not sure
    A: If you could do any of the capability plots on the critical to quality requirements, this will give you an understanding on their capabilities. I suggest you to ask their control plan and investigate the opportunities for improvement.
    A: This depends on several variables. You need to come up how important are at your production facility. need more information to answer. You can switch to c=0 sampling plans, but you would reject the entire lot.
    this material will help you to resolve lot of your queries:
    Link: http://www.ombuenterprises.com/Libr...tance_Sampling_Understanding_How_it_Works.pdf
    Thanks,
    Vik
    QMSmaster likes this.
  5. Bev D
    503
    545
    The c=0 sampling plan (for AQL based plans) actually provides less protection to both you and your suppliers. This type of plan arose several decades ago when some 'customers' who didn't understand statistics or probability couldn't explain how it was OK to have some defects in your sample and accept the lot even tho they had an Acceptable Quality Level greater than zero. They put the c=0 plan in place to make themselves feel beter but it's like taking valium. you feel great but your quality doesn't get better.
    you can get a copy of the following excellent paper at ASQ through the knowledge center. price is $10 for non members and $5 for members. well worth it.
    Acceptance Sampling? The Enterprise Strikes Back! AS9100c = 0 Plans; when Slogans Supplant Science
  6. Bev D
    503
    545
    Vthouta likes this.
  7. tony s
    1,256
    954
    If your organization subscribes to ISO/TS 16949, one criteria that you need to consider is on the Clause 7.1.2 which says that "Acceptance criteria shall be defined by the organization and, where required, approved by the customer. For attribute data sampling, the acceptance level shall be zero defects (see 8.2.3.1)".
