9001 Risk Based Thinking
Discussion in 'ISO 9001:2015 - Quality Management Systems' started by Somashekar, Oct 15, 2015.
  1. Somashekar
    Somashekar Well-Known Member
    114
    98
    SUB : 9001: Risk Based Thinking
    Hi all. Newbie.
    We are a smallish (60 people) engineering company certified to 9001:2008.
    With the recent release of the new 9001:2015 standard, do our current manufacturing procedures and work instructions cover the RBT?
    Thank you for any comments.
    {Post in my inbox from New member Inspector 2s}
    Difficult to tell without seeing them. Procedures and work instructions are, in pure terms, about process control. If there is inherent risk that the authors of such documents are aware of, risk treatment may have been included in them. Otherwise, it's best to perform an evaluation of risks and see if the document talk about that.
  3. yodon
    216
    130
    If it's strictly manufacturing procedures, chances are there will be some RBT embedded (maybe some in-process tests) but the expectations, I believe, are for the company to take a more holistic view of risk.
    Just some things that come to mind...
    * When you take on a new job, is it introducing new risk (skills, equipment, production rate, etc.)?
    * What if parts shipments are late? Or short?
    * Are all the specifications complete? Are you having to make assumptions?
    This would, I believe, also include any business continuity considerations.
    So take a step back and think broadly. Presumably you're doing process-based internal auditing so consider risks associated with each of those processes (risks to the business, risk to the customer, risks to operators, and so on).
    The challenge will be meeting auditors' expectations! Who knows what will be considered enough (in the eyes of the auditors).
    Jennifer Kirley and Somashekar like this.
    One example, I'm fairly familiar with is when suppliers are sourced/changed. If you are mature about RBT, your procedures will consider what's important to control from that new supplier - is it a proprietary part for example? Or is it made to print and you have a problem trying to check the material which, if let into your process may not become apparent until the customer gets and uses your product. What do your procedures say about planning for supplier initial checks/certifications of materials/inspection results etc?
  5. Eric Twiname
    329
    232
    Ewww...there's a term and mindset I hope doesn't catch on...
    Probably isn't what I meant, as I was on the phone when I wrote it... Duly edited.
    Eric Twiname likes this.
  7. Eric Twiname
    329
    232
    I figured not...but couldn't/didn't resist... :rolleyes:
  8. NISHITH NEEMA
    NISHITH NEEMA Member
    Sep 15, 2020
    In the new standard 9001:2015 there is the following new clause
    4) Context of the organization
    4.1) Understanding the organization and its context
    4.2) Understanding the needs and expectations of interested)
    so you need to add only a new document 1Identification of Interested parties (stake holders) with context
    then 2.and there expectation of interested parties
    RBT is whatever you say it is. Typically, procedures and work instructions do not manage risk.
    No "new documents" are required for the Context of the organization. Indeed, that section doesn't mention the need to "maintain documented information"...
  10. John C. Abnet
    Good day @Somashekar;
    You have received some good council . As mentioned by others, risk based thinking is not about specific documentation, but instead it is intended to ensure a particular approach is used by organizations certified to ISO 9001. ISO 9000 ("Fundamentals and vocabulary"...this document may prove extremely helpful to you), defines risk as "effect of uncertainty", and goes on to describe "effect" as potentially negative or POSITIVE. In other words, risk is any event that can cause your organization to not meet intended results. What are your organization's objectives? Does your organization use any current disciplines such as SWOT, or PFMEA or specific planning meetings, or ????....where your organization reviews and responds to risks?
    Below is information I posted previously in response to a similar question....
    "ISO 9001 has no requirement for 'scoring' or having a matrix listing risk and opportunities. Keep in mind, while clause 4 (specifically 4.1 and 4.2 ) need to periodically reviewed, the information you identify here (essentially WHO are we, WHAT do we do, WHO cares, and WHAT do they care about), rarely changes in most organizations.
    Risk and Opportunity, however, change regularly. For example, fuel prices are currently extremely low. In part because of the fussing between Russia and Saudi Arabia, but also because of the current health crisis. This "risk" or "opportunity" (if you are a US shale producer, huge RISK, if a logistics company, huge OPPORTUNITY). was likely not on the radar (or a matrix) of the industries in my example six months ago.
    Risks and opportunities are very dynamic. Regardless of what ISO 9001 requires, your organization would likely benefit from frequent (e.g. monthly? ) reviews of risks and opportunities that present themselves.
    I assure you, USA shale producer company's Top Management did not wait month(s) to take action when per/barrel prices of oil started this recent significant drop.
    Hopefully from my ramblings you can see why a fixed "matrix" of risks and opportunities might not benefit your organization. ALWAYS do what helps your organization...NOT what simply pleases an auditor."
  11. tony s
    The controls that your organization had specified in your procedures and work instructions may demonstrate that risks inherent in your manufacturing processes are being addressed (e.g. inspection controls address risks on receiving defective materials, discrepant in-process and outgoing products, calibration and maintenance controls address risks on equipment/instrument wear and tear, etc.). What about the non-manufacturing processes? The 2015 standard, in clause 4.4.1f, intends organizations to address risks/opportunities in all processes needed for the QMS.
    The statement in 4.4.1f also mentioned "as determined in accordance with the requirements of 6.1". Thus, organizations will need to demonstrate that:
    • the risks and opportunities needed to be addressed were determined during planning while taking into consideration the internal/external issues and needs/expectations of interested parties;
    • the actions that were identified were integrated/implemented (see also 8.1 first paragraph) into the processes of the QMS (not just manufacturing processes);
    • the actions were evaluated for their effectiveness.
    Organizations will also need to demonstrate that, in evaluating the effectiveness of the actions to address risks/opportunities, data were obtained and analyzed (see 9.1.3e). The results of the analysis and evaluation should be made available to the top management for their review and disposition (see 9.3.2e).
    If your organization has adequately covered the requirements in the clauses mentioned above, then, I believe, your RBT approach can satisfy the relevant requirements of ISO 9001:2015 standard.
