9.2.2.3 Manufacturing process audit
Discussion in 'IATF 16949:2016 - Automotive Quality Systems' started by Victoria D, Feb 1, 2018.
  1. Victoria D
    Victoria D Member
    Jan 26, 2018
    Trying to determine how far to drill down for a manufacturing process audit when creating an internal audit schedule. For example, we have two different lines that both fall under "assembly", but those lines produce different products.
    1. Do we need to conduct a manufacturing process audit for each assembly line even though they both fall under the assembly process?
    2. The assemblies may be assembled via installation of fasteners, resistance welding, or robotic welding, etc.
      1. Does each method (fastener, welding, etc) of assembly need to be listed as its own process from a manufacturing process audit standpoint or am I overthinking this?
    Yes, and to set a priority, which one produces most problems? That's the one to go after, first.
    Victoria D and normzone like this.
  3. normzone
    normzone Well-Known Member
    137
    78
    Welcome to the forum, [Victoria D]. Nice avatar ....
    Victoria D likes this.
  4. Victoria D
    Victoria D Member
    Jan 26, 2018
    Thanks for the responses!
    Being new to IATF I could really use some clarification between Manufacturing Process Audits & Product Audits. Is my understanding correct?
    Manufacturing process audits: control plan audit will suffice
    Product audit: ensuring customer specifications are met anywhere
    throughout the process - first piece inspection, in-process inspection, final inspection,
    labeling, packaging, etc
  5. Serious Man
    Serious Man Active Member
    Oct 24, 2017
    79
    28
    I think that before reconsidering programm of manufacturing process internal audits, your company should think once more about how do you establish manufacturing process.
    Processes with different requirements, different control methods, different failure occurrence and severity should not be put under one umbrella of "assembling".
    I mean here PFMEA and its impact on control plan development and manufacturing process itself.
