Sample size determination and effect size
Discussion in 'DOE - Design of Experiments' started by mmmarta, Apr 12, 2023.
Tags:
  1. mmmarta
    mmmarta Member
    Apr 12, 2023
    Hi all,
    I have to run a doe and I need to estimate the number of repetitions.
    How do you handle this estimation when you do not know the variance of the process and the effect size?
    Could be ok to run a hypothetical number of reps (e.g 3) and after collecting data assess the power of the test? Eventually adding more reps if necessary.
    Another doubt I have is: how can I assess for the effect size given that I have a multilevel multifactorial doe? The effect size is the difference between the means. Which one to select among all the level I have?
    Do you have any suggestion?
    Thank you in advance for your help!
    Bye
    578
    DOEs are a very complex topic that is difficult to cover in a post, but I will try to cover the basics.
    • Starting with your use of the word repetitions, DOE distinguishes between repeats and replicates.
      • Repeats are multiple measurements taken during a single experimental run and only include short-term variation. They provide minimal value to the DOE.
      • Replicates are different from repeats by performing a specific experimental run multiple times. This includes setup variation and provides additional degrees of freedom to the experiment. Replicates add value to the DOE, but also add cost by increasing the size of the experiment.
    • Regarding the process variance, do you have any historical data of any type? This could be from a capability study or even production records. It does not need to be precise; a ballpark estimate is sufficient. You can also run the calculation for various estimates to see how sensitive the number is to the variation.
    • Regarding the effect size, you should already know how much the process swings high to low. Pick an effect size larger than this that is large enough to justify the expense of running this experiment. Don't worry about the multiple factors. ANOVA looks for the largest effect.
  3. mmmarta
    mmmarta Member
    Apr 12, 2023
    Hi Miner, thank you for your reply!
    • I apologize, I meant replicates.
    • Regarding the variance. Unfortunately, we do not dispose of any previous data.
    • Ok, thank you. I will pick up the largest effect, but now, as for the variance, I have no clue of its entity.
    Do you think that the approach of running a hypothetical number of replicates and, only after collecting, data assess the power of the test could be a possible solution?
    Thank you again!
    Bye
  4. Miner
    578
    I do not recommend that. It would be simpler to monitor your process for a day, collecting the data needed to calculate the variance.
    mmmarta likes this.
  5. Bev D
    606
    664
    Miner is correct. Assessing power after the effect is a mathematical exercise that has no meaning.
    mmmarta likes this.
  6. mmmarta
    mmmarta Member
    Apr 12, 2023
    Got it, thank you very much!
    Bye
