Help with developing a Control Plan for a non-manufacturing company
Discussion in 'Documentation Control, Procedures, Templates,...' started by claudiogut, Mar 1, 2023.
Tags:
  1. claudiogut
    claudiogut Member
    Aug 10, 2019
    31
    The company I work for is being audited by a big potential customer and they want to see a proper control plan, the problem is that this company doesn’t actually manufacture anything. They’re just a distributor of parts.
    Basically, they will stock items for the potential customer and sell to them as needed.
    There are only simple processes involved in the handling of material:
    1. Receiving
    2. Incoming inspection
    3. Stocking
    4. Picking
    5. Outgoing inspection
    6. Shipping
    Can someone point me to resources and templates for something like this? All I find online are templates for companies that manufacture things.
    Thank you in advance to anyone that answers!
    577
    The templates would be the same. You say that you perform incoming and outgoing inspection. Document that on your control plan. What do you inspect? How many? How often? What measuring devices? etc.
    claudiogut and Andy Nichols like this.
    5,101
    2,557
    Exactly so. Don't forget to base the control on past performance of quality etc. If you have had no issues, then simply do an i.d, condition and count check to the PO requirements.
  4. claudiogut
    claudiogut Member
    Aug 10, 2019
    31
    @Miner thanks for your reply. I suppose we wouldn't list every single part that we inspect, but rather a family of parts that have their own set criteria and reference that document number, correct?
    And @Andy Nichols I'm not too clear on how to base the control plan on past performance. What do you mean by this?
  5. Miner
    577
    I would definitely take that approach.
    He probably means to look at what you currently inspect, and look at your history of rejections and returns for each item. If you have never had a rejection or return for a given item, consider removing it from your plan.
    5,101
    2,557
    Yup, got it!
  7. claudiogut
    claudiogut Member
    Aug 10, 2019
    31
    Gents, in reviewing existing templates and sample control plans from other organizations, they all seem to be unnecessarily complicated and detailed. We're a simple distributor of components.
    So my question to you is, could it be as simple as the attached files?
    5,101
    2,557
    Most certainly! The process flow is a good model to follow.
    In the case of the Control Plan, the idea of using an AQL to sample is an unnecessary complication. Although it has been used commonly for such situations (in a past life we used it in receiving inspection for COTS items) it really has no place - unless you apply the statistics behind it correctly.
    As stated previously. Unless there's been a history of poor quality performance (quantity, damage, wrong/mixed items etc) then simply do an ID, quantity and damage check to the PO and put them in location. Depending on what you have, a periodic condition check etc is common as is counting inventory turns, FIFO etc. as part of the CP.
    Miner likes this.
  9. claudiogut
    claudiogut Member
    Aug 10, 2019
    31
    @Andy Nichols, thanks for your feedback. This customer is particularly finicky and they want everything at AQL 2.5, so I have to specify it in there. I will touch up the control a little more with resource names, etc, but I want to keep it as simple as possible.
    Thanks again for your vote of confidence!
    5,101
    2,557
    You are welcome
