Delayed corrective action - what to do
Discussion in 'ISO 9001:2015 - Quality Management Systems' started by Devesh#89, Jan 7, 2025.
  1. Devesh#89
    Devesh#89 Member
    Jun 29, 2024
    31
    if there is an audit observation that VAPT (penetration testing for servers and software) was not done and corrective action is taken that the VAPT will be conducted in December 2024 but the organization failed to conduct the VAPT due to some internal or budget issues, as a QMS person should I initiate planned deviation and how it will impact the future audit
    Devesh: when you say audit “observation”, do you mean a non-conformity? What type of audit found this “observation”? What requirement was the audit being conducted against? This is posted in the ISO 9001 forum and it doesn’t mention penetration testing.
  3. Devesh#89
    Devesh#89 Member
    Jun 29, 2024
    31
    Ok let me give a short brief, i know it is for ISO 9001 but this is as per ISO 27001 (ISMS) it is mandatory to conduct VAPT (Vulnerability Assessment and Penetration Testing) regularly (Annually in this case) this test ensure that all your servers or IP addresses are working as per standard and are secure from any potential cyber threat so a tester try to breach the security to test stability and security of these IPs.
    On the basis of this VAPT which organization failed to conduct at the time and certifying body issued a major non-conformity and organization took corrective action that they will conduct this in december 2024 but as per the changes in IT infrastructure it seems that it will not possible to conduct that test again before decemeber 2024 so that what happened.
    Now on the basis of above scenario i want your POV that can't we initiate a planned deviation as a proactive approach to save another critical or major observation
  4. Bev D
    Well do the test now.
    Adn then I would investigate why it wasn’t done in December 2024 as promised. Why the heck wouldn’t a company perform a test that is so protective to THEM? Let alone one that got you a major NC?
    I think there may be a lot bigger problems with this company….
    Really? Can you point to the requirement so I can read it?
    I think the factors that prevented the conduct of the VAPT as per the annual schedule also prevented the implementation of the rescheduled testing on December 2024. Actually, just rescheduling the test is not a corrective action. Your problem will just keep on persisting unless your organization address the factors preventing the implementation of the VAPT. As a QMS person, you need to have a good understanding of the definition of the term corrective action. Determine the factors mentioned then implement actions to eliminate them.
    In addition to Tony's great comment, I'm also wondering what the internal auditors were doing! How can any organization have allowed such a huge hole to develop in its ISMS, without an internal audit at least confirming the situation? My guess is...
  8. Devesh#89
    Devesh#89 Member
    Jun 29, 2024
    31
    I know but what if organization having budget issues to conduct the VAPT on time how could we solve that then?
    I don't understand your question...
  10. Devesh#89
    Devesh#89 Member
    Jun 29, 2024
    31
    See i know there is a problem with organization in maintaining QMS or ISMS but my question is that organization issues budget to do these VAPTs but what if the Budget was the reason for that non conformity, so how should we handle that?
  11. Bev D
    What do you mean the budget was the reason? Did your company run completely out of money? Did they not budget for this required testing? Sound like they are giving lame-@$$ excuses and a corrective action won’ t change that
  12. Andy Nichols
    Who is running the company? Finance? Who budgeted for pen testing? Was the pen testing included in the pen testing but the funds not made available. Like any corrective actions, you have to a) determine the actual problem and write it down and b) work to find a root cause.
    "Problem: Budget for pen testing, required to ensure ISMS is not at risk of external hacks which can cost $XM to recover and should be completed annually and before ISMS certification audit (for example) wasn't...
  13. Golfman25
    Simple. Go out back to the money tree and get some.
    Assuming this is an important test for your organization it seems you have a few things going on. You’ll obviously need to delay finishing your corrective action. You’ll want to note why the delay is necessary. You’ll also want to explore why this can’t be part of standard operating procedure and not subject to lack of budget. This is likely beyond your pay grade, so you’ll want to kick it up to the powers that be and get their input. Good luck.
  14. Devesh#89
    Devesh#89 Member
    Jun 29, 2024
    31
    Thanks andy
  15. Devesh#89
    Devesh#89 Member
    Jun 29, 2024
    31
    Thanks, golfman!!!
  16. Devesh#89
    Devesh#89 Member
    Jun 29, 2024
    31
    Hi Everyone, I came up with a request, is it possible to have a kind of questionnaire or a resource with findings with which i can improve my clause application skills to different different findings?
  17. Andy Nichols
    In what respect? Can you give an example? What are “findings”? Product? Process? QMS?
  18. Devesh#89
    Devesh#89 Member
    Jun 29, 2024
    31
    Hi Andy, i just want some mock findings (A report or a checklist) to test my understanding of ISO 9001 clauses. for example " it was identified that the folder structure for archival data was inappropriate" so will this finding go with clause number 7.5.2(c) or with 7.5.3.2(b).
    Hope you get it what i want.
  19. tony s
    The requirements within the ISO 9001 standard are just part of the criteria that an internal auditor should cover. Clause 9.2.1a may have intentionally put the phrase "2) the requirements of this International Standard" second in importance than "1) the organization’s own requirements for its QMS". But, since there's a requirement in clause 4.4.1 that specifies "The organization shall establish, implement, maintain and continually improve a QMS, including the processes needed and their interactions, in accordance with the requirements of this International Standard", organizations will need to integrate the QMS requirements into their processes (see clause 5.1.1c).
    Organizations need to understand first their processes before knowing the clauses/requirements which are relevant to support the processes. For example:
  20. Andy Nichols
    Devesh, this isn’t something a) in ISO 9001 as a requirement and b) it’s just an opinion. You cannot test understanding against an opinion.
