Deciding Vernier Caliper verification tolerances
Discussion in 'Gage Calibration and Uncertainty' started by MonsterEnergy22, Sep 20, 2023.
  1. MonsterEnergy22
    MonsterEnergy22 Active Member
    Nov 30, 2022
    56
    United Kingdom (England)
    Good Morning,
    I'm hoping some one can be help me, this will be a very brief & basic question.
    We currently verify our Digital Vernier Calipers in house against a set of externally-calibratied slip gauge blocks.
    When writing the calibration/verification procedures, there was no original equipment manufacture's tolerances stated so we decided upon +/- 0.2mm (it was literally just decided) , we've been happy with this since then.
    However, a new mechanical engineer expressed his shock when he heard this and said it should be +/- 0.01mm , I didn't really have an answer for him as to why it should/shouldn't be as such.
    We have our material tolerances specified for all types of materials, for example, cutting lengths of steel material has a tolerance of +/-1mm,
    obviously if the vernier had a reading error of 0.2mm this could potentially result in non-conforming materials.
    Is/are there any resources available to better understand this process?
    I greatly appreciate any replies as always.
    Have a nice day.
    The general industry practice is a 10:1 ratio. Thus if measuring to 1mm, the equipment should read to 0.1mm and be verified/calibrated with something which is 0.01mm
  3. MonsterEnergy22
    Nov 30, 2022
    56
    Thank you for your reply Andy & apologies for my question of a rudimentary nature. I appreciate your help as always.
    Whilst the concept of a 10:1 ratio and your explanation is perfect, are there any recognised documents that go into detail regarding the 10:1 rule?
    EDIT:
    as a thought,
    I've verified my Vernier that reads to 0.1mm with a calibrated item that reads to 0.01mm.
    How do I decide the acceptable tolerance limit? for example as I stated earlier, I allow for +/- 0.2mm deviation from the nominal value?
  5. Md. Hasan Ibrahim
    Md. Hasan Ibrahim New Member
    Aug 21, 2023
    Bangladesh
    Selecting the right tolerance for caliper verification is crucial. While +/- 0.2mm may suit some applications, precision demands, especially in manufacturing, often require tighter tolerances like +/- 0.01mm. The choice depends on your specific use case and the acceptable margin of error. Consulting industry standards, collaborating with experts, or referring to equipment specifications could provide insights for a more informed decision. Best regards
  6. MonsterEnergy22
    Nov 30, 2022
    56
    Hi Hasan,
    Fortunately, my organisation doesn't require anything extremely precise.
    Since posting this thread I discovered a R&D general tolerances for manufacture, to which many tolerances were "0.01mm", based upon that, I moved to 0.01mm :)
