Daily Checks for coating
Discussion in 'IATF 16949:2016 - Automotive Quality Systems' started by S1D3K1CK, Jan 31, 2023.
  1. S1D3K1CK
    S1D3K1CK Active Member
    Nov 5, 2018
    73
    26
    The Central Valley
    Hello all, I am up against something I am not familiar with. We have to perform daily sample test, per substrate. Our requirements are: Dry film thickness (mils or microns)(tolerance provided by coating manufacture), Dry adhesion (5B,4B,3B etc.), Scratch hardness (2H, H, F, HB etc.), Wet adhesion (5B, yada-yada) and MEK solvent resistance (pass or fail).
    Is there any calibratable equipment available in order to perform these test? Preferably one setup. Also, what typical inspection report is used for documentation?
  2. qmr1976
    qmr1976 Well-Known Member
    Jun 17, 2019
    155
    83
    Have you tried referencing the AIAG CQI-12 Coating System Assessment manual for guidance? Coating isn't what we specialize in, but we have a sub-supplier that coats parts for us. Probably not much help here, but just thought I would throw that out there. :)
    S1D3K1CK likes this.
    5,086
    2,553
    Can you share some background (specifically since this is the IATF group) - did this come from a PFMEA as a response to a failure mode?
  4. S1D3K1CK
    Nov 5, 2018
    73
    26
    The Central Valley
    Thank you! I will be sure to review that.
    qmr1976 likes this.
  5. S1D3K1CK
    Nov 5, 2018
    73
    26
    The Central Valley
    This resulted from reviewing a requirement for adding a secondary coating supplier, for future capacity issues and reduction of lead times. The new coating supplier is capable of meeting all the requirements per our customer with using the approved powder, but the CSR states all new coatings suppliers are required to submit test samples for initial approval, complete daily testing on all substrates provided to the customer (retaining all inspection reports) and annual testing to maintain approval. Plus, they would like to introduce a new powder.
    5,086
    2,553
    OK, if I understand this isn't what your organization does (apply coatings) but a supplier? In that case, can't you/shouldn't you be using their capabilities to perform the testing? Correct me, if I have it wrong, but you shouldn't be doing these tests (at additional cost and risk) when the supplier - or an independent lab - should/could?
  7. S1D3K1CK
    Nov 5, 2018
    73
    26
    The Central Valley
    Andy, I agree 100% with you. I believe there could be misinterpretation with who they are referring to as the "supplier" at that point. It could be that they are referring to the Tier 2 supplier (coatings) is responsible for the testing, lab results and other requirements and the Tier 1 supplier (us) is required to maintain the approvals and providing necessary documentation to the Tier 2.
    5,086
    2,553
    Where is this “requirement” defined and by what function?
