Chemical Storage
Discussion in 'ISO 14001:2015 - Environmental Management Systems' started by fadhel, Jul 3, 2024.
Tags:
  1. fadhel
    fadhel Member
    Mar 1, 2024
    When SDS refers to : Store locked up. that means the chemical must be in secure place or its mandatory to have it under Lock and key .
    Thank you
    5,451
    2,703
    If it says "secure" then that can be achieved by more than "lock and key". No "standard" is going to prescribe a specific item such as a lock with a key because there may be many, many more methods to make it secure. It's your choice how you make something secure.
  3. John C. Abnet
    767
    Good day @fadhel , and welcome to the site.
    Please help us understand: what is the purpose/intent of your post? Are you asking a question?
  4. fadhel
    fadhel Member
    Mar 1, 2024
    Hello Again
    @John C. Abnet we had an audit and the auditor raised an observation regarding an Oil Barrel which was stored and bunded within the permisses and when she checked the SDS file she found it was mentioning STORE LOCKED UP . my thoughts was same as @Andy Nichols but anyways wants to be sure for this time and future .
    Thank you
    5,451
    2,703
    If a Safety Data sheet says "locked up" then that's what it means. This is posted in ISO 14001 forum - which is environmental.
  6. John C. Abnet
    767
    As @Andy Nichols says---although I've never seen an SDS that indicated specifically "Store Locked Up" , then that is the requirement. (also, if the manufacturer/SDS put such detail, then for SAFETY'S SAKE why wouldn't your organization want to "Store Locked Up" ??
  7. fadhel
    fadhel Member
    Mar 1, 2024
    @John C. Abnet Thank you for your response . during an audit was highlited this issue that it has been stored under Lock and key while already its stored in secure area just without lock and key .
  8. Wavellow
    Wavellow New Member
    May 16, 2025
    We keep acids and bases on separate shelves with spill trays, good labeling, and updated SDS printed and on hand. Flammable stuff goes in a vented metal cabinet away from ignition sources.
  9. Wavellow
    Wavellow New Member
    May 16, 2025
    Yep, “Store locked up” on an SDS means exactly that—it should be kept under lock and key, not just on a high shelf or in a random cabinet. It's usually required for toxic, corrosive, or otherwise dangerous substances to prevent unauthorized access or accidents. Especially important if others share the space or if there are kids around.
    Also a good reminder to invest in proper linked removed —like lockable storage cabinets, labeled containers, and safety data sheets easily accessible nearby. A little caution goes a long way in keeping everyone safe.
