Within specification or out of specfication
Discussion in 'Other Quality and Business Related Topics' started by Plague Doctor, Jun 30, 2017.
  1. Plague Doctor
    Plague Doctor Member
    Jan 19, 2016
    Ukraine
    There is a spec requirement for dimension - 1,3 +/-0,3 mm
    The measured value is 1,68 mm
    Is it:
    1. within spec because the first out-of-spec value is 1,7 and 1,68 is lesser and thus in spec
    or
    2. out of spec because the last within spec value is 1,6 (should be interpreted as 1,60) and 1,68 is bigger.
    BTW, the rounding is not applied in measurements, am I correct?
    So its not right to consider 1,61 - 1,64 mm as 1,6 mm. and 1,65 - 1,69 mm. as 1,7 mm?
    Thank you.
    710
    Good day Plague Doctor;
    It is always best to go directly to a consensus standard to provide basis and objectivity. ASME Y14.5M paragraph 2.4 provides the following...(see attached).
    Plague Doctor likes this.
