What is the impact if gages calibrated at 20° are used at 35°
Discussion in 'Gage Calibration and Uncertainty' started by shankar Jadhav, Oct 8, 2015.
  1. shankar Jadhav
    shankar Jadhav Member
    Sep 5, 2015
    Why we do calibration in 20 ° and we are using gauges at temp about 30 to 35 °. what is the impact on gauge. please anyone explain.
    576
    492
    It depends on the gauge and the materials comprising it. Essentially, your concern is with the coefficient of thermal expansion. This would affect both the gauge and the feature measured.
  3. equilibrium
    equilibrium Member
    Aug 10, 2015
    32
    I would also consider tolerances on what is being measured. For example, this is much more of a concern when tolerances are in the tenths (.0001") range versus the ten thousandths (.010") range.
  4. Bob Doering
    Bob Doering Member
    37
    Maybe a little more clearly, the material the gage is made of versus the material you are measuring. It is the difference in thermal coefficient of expansion that creates error. Stainless steel gages versus aluminum parts outside of standard temperature....you will be chasing your tail!
    Emmyd and Miner like this.
  5. alex41
    alex41 New Member
    Aug 15, 2023
    This question is really confusing. How should we answer the auditor?
    5,086
    2,553
    Alex: Tell us more about the background to you post, so we can help...
  7. alex41
    alex41 New Member
    Aug 15, 2023
    If a device calibrated at 20°C is used at 35°C, how does the temperature change affect the process?
    5,086
    2,553
    Which part are you having a problem with?
