Transfer of Document Ownership
Discussion in 'Documentation Control, Procedures, Templates,...' started by Hui Ying, Jul 23, 2019.
  1. Hui Ying
    Hui Ying New Member
    May 2, 2019
    Dear fellows,
    Good day to you!
    I am given a task in establishing the workflow of transferring the document ownership in my organization. Instead of just obsoleting the document, we are looking into ways to keep the history of the affected document and change its ownership officially.
    I drafted a workflow for this purpose. May I have your favourable comments?
    Thank you in advance.
  2. RoxaneB
    923
    1,072
    Hello, Hui Ying.
    To make this document more meaningful, I think it's missing a lot of information. It has a good starting point by saying WHAT needs to be done, but it doesn't include WHO or HOW. For example, HOW is the document initiated and WHO does that? HOW is the notification done and by WHOM? Is it a phone call from the front desk receptionist or an email from you?
    HOW is knowledge transfer done? What if it's not an area you're familiar with?
  3. Hui Ying
    Hui Ying New Member
    May 2, 2019
    Dear Roxane,
    Appreciate your advice!
    We have yet to go into the details of this process so there could be quite a number of missing information :)
    Just curious, can we ‘obsolete’ a document to manage the transference of an active document, instead of setting up a process to transfer the ownership of a document?
    4,593
    2,308
    It seems to me that this should be a simple case of "document change control". What mechanism do you currently use to initiate and process a change? I always advocate the use of some type of change notice - modeled after an engineering change request - which can be used to take care of the change of ownership or anything similar to do with a document. If you are thinking of a unique process, then you are likely making this more complex than it needs to be.
  5. RoxaneB
    923
    1,072
    When a document is rendered obsolete, it is because it is no long applicable to the organization.
    If your organization is transferring ownership, it sounds as if the document is still required, so rendering it obsolete does not seem applicable here. Or is there more to the story here? :)
    To Andy's point, if you have a document revision process in place that includes updating and controlling changes, both transferring ownership of a document and rendering a document obsolete would fall into this process.
