Training type decision when SOPs are revised
Discussion in 'ISO 9001:2015 - Quality Management Systems' started by laden, Sep 7, 2020.
  1. laden
    laden Member
    Apr 21, 2020
    I'm trying to set an approach for deciding training types when a SOP is revised.
    How is the best approach on that? For example when a document is updated, the training can be doable as a self tranıng or process owner supposed to perform the training..how can we classify ?
    4,423
    2,226
    Have the process or requirements changed? Did you ask the people doing the job?
  3. yodon
    156
    89
    Consider the level of risk related to not following (or not understanding) and the effectiveness of the approaches. Some low-risk processes may be fine for a "read-and-understand" whereas higher risk may require more intensive training. And recognize this may be different for different roles. For example, if you have a Purchasing SOP, maybe someone who just coordinates with the purchasing group may just need to read whereas someone in the purchasing group may need interactive training. The changes may also drive your decision. Edits for, say, grammar or layout may require very little whereas a fundamental change to the process would likely require more.
  4. NISHITH NEEMA
    NISHITH NEEMA Member
    Sep 15, 2020
    How is the best approach on that? For exasemple when a document is updated, the training can be doable as a self tranıng or process owner supposed to perform the training..how can we classify ?
    Dear Mr. Laden,
    The clause 7 of ISO 9001:2015 will help you in deciding the action plan
    It says"The organisation shall determine and provide the necessary resources for the establishment and implementation, maintenance and continual improvment of the quality management syste."
    Hence you will decide as to what SOP or document you have modified and how does it relate to the effect the organisation.
    For any query you can revert back.
    4,423
    2,226
    Why? All you have to do is decide if there's a new skill required. SOP changes usually only need awareness, not training. Training, in general terms, develops skills. Making people aware isn't training.
  6. RoxaneB
    917
    1,065
    I think @NISHITH NEEMA was copying instead of quoting the original post from @laden . His response then follows "Dear Mr. Laden,..."
    4,423
    2,226
    Indeed! I see it now. Thanks for the clarification...
    I'm not sure the standard gives much help, other than pointing out what is required. It's a common misconception that when documents change - especially procedures and work instructions - that for some reason "training" is always needed. Sadly, ISO 9001 is zero help in this regard...
  8. John C. Abnet
    615
    428
    Good day @NISHITH NEEMA ;
    You have received good clarification from @RoxaneB and council from @Andy Nichols.
    Consider this....
    ISO 9000:2015 speaks to the term "competence" as follows..
    2.2 Fundamental concepts:
    2.2.5.3 -
    "A QMS is most effective when all employees understand and apply the skills, training, education, and experience needed to perform their roles and responsibilities.
    3.10 Terms related to characteristics:
    3.10.4 Competence-
    ability to apply KNOWLEGE and skills to achieve intended results.
    As you can see, the standard speaks to "...needed to perform..." and "... to achieve intended results..."
    When considering if/when to apply awareness and/or training, It is important to first identify what is needed and what the intended results are.
