Thread gauge calibration/verification
Discussion in 'Gage Calibration and Uncertainty' started by shndcb, Apr 15, 2016.
  1. shndcb
    shndcb New Member
    Apr 14, 2016
    Can I use the shadowgraph and Mylar to calibrate the thread gauge?
    I think this is much easier and faster than 3 wire method.
  2. equilibrium
    equilibrium Member
    Aug 10, 2015
    32
    Could you provide some information on your application/industry? Without more information, this would be difficult to answer.
  3. shndcb
    shndcb New Member
    Apr 14, 2016
    Automotive seating industry. using some thread gauges to check nuts and stud thread. Like M6X1 M8X1.25 M10X1.5 and 7/16 20 standard threads.
    5,086
    2,553
    Can I ask why you're doing this?
  5. shndcb
    shndcb New Member
    Apr 14, 2016
    all our gauges have a calibration frequency and need to be calibrated like once a year.
    5,086
    2,553
    This is a common practice. The OP is asking about a specific method of calibration.
  7. equilibrium
    equilibrium Member
    Aug 10, 2015
    32
    I'm not in automotive, or very familiar with their requirements. From my perspective, the three-wire method is still preferred. That way an actual number can be derived, rather than a go/no go result from an overlay. While we've never used the data extensively, it has helped with inventory control and indicated where more gaging was needed, based on wear.
    As to the calibration frequency, we base that on usage. Thread gages are sealed after calibration and are returned after 3 days of use. This actually began as a somewhat arbitrary selection (before my time here), but we now have about seven years of data to support that decision. Threaded ring gages and specialty thread measuring gages still go to outside calibration services because we're not equipped to measure those in-house.
  8. QMSmaster
    QMSmaster Active Member
    Dec 29, 2015
    have you ever seen how a plug thread gage is calibrated? You probably do not have the correct equipment for that either.
  9. RoxaneB
    That was the OP responding to your question about why s/he is doing this. ;)
    5,086
    2,553
    OOOppps! But really I was asking why studs and nuts are being checked...:D
  11. RoxaneB
    Who was this directed towards, QMSmaster?
  12. QMSmaster
    Dec 29, 2015
    The OP. You need more than a micrometer and a 3-wire kit.
  13. Andy Nichols
    5,086
    2,553
    Before anyone decides which is the best method, shouldn't we be asking what the gauge is being used for and then, does it need to be calibrated? Since the OP hasn't replied other than to say their procedures require calibration, I'd suggest that if the gauge is being used:
    • to identify if the thread size is correct, then no calibration is required (it's just being used as a nut, in effect) or
    • to identify the class of thread, then calibration is probably a good idea.
    Without answers, we can debate all day and get wrapped around the axle about calibration, equipment and methods, with the result that, potentially, vast sums of money are wasted on something which may be brought into question later (hopefully by management)
    RoxaneB likes this.
  14. QMSmaster
    Dec 29, 2015
    fair comment
  15. gaugestools
    gaugestools Member
    Dec 3, 2017
  16. Andy Nichols
    5,086
    2,553
    Still haven't figured why nuts and studs are being checked...
  17. gaugestools
    gaugestools Member
    Dec 3, 2017
    No, I think it is better use 3 wire method
