Standard for rounding measurements
Discussion in 'Sampling, Standards and Inspection' started by Ryann Hill, Sep 6, 2016.
  1. Ryann Hill
    Ryann Hill New Member
    Good Morning,
    Does anyone know if there is a standard that discusses rounding of numbers regarding measurements? for example you have a measurement of 12" but want to convert it to mm for labeling purposes.
    Thanks in advance,
    Ryann
    578
    Be careful in rounding numbers. Due to rounding, results below can happen:
    I'm using this freeware for conversion. Unzip it to use it.
  5. rmf180
    rmf180 New Member
    Sep 18, 2015
    I have worked with customers who treat significant digits as the only rule (3 place print, 3 place results), customers who specify ANSI E29, and others who look at print +1 (3 place print, 4 place result).
  6. Eric Twiname
    329
    232
    LOL...In my experience, each customer has their own "standard".
    The only across the board standard I've seen is "only round the final result"...see tony s in post #3 above.
  7. RoxaneB
    In line with Tony and Eric, I remember the discussion that 1+1 does not always equal 2.
    1.4 rounded = 1 yet:
    1.4+1.4 = 2.8 = 3
  8. Bev D
    606
    664
    things that appear simple really aren't...
    math and intent matter
    significant digits and measurement resolution are critical to 'safe' rounding.
  9. Eric Twiname
    329
    232
    ...and for playing piano...
    (pause, think about it...)...:p
  10. charanjit singh
    charanjit singh Member
    Jan 21, 2016
    32
    When rounding, one must know to what significant decimal place one is permitted to round off. For example, if we are to round off to one decimal place, the second decimal place (if present) will just be ignored if it is '4' or less. But if the second decimal digit is 5 or more, the first decimal digit will be increased by one before dropping the second decimal place.
    In fact this rule applies to any number with any number of decimal places. That is to say that Nth decimal digit should be increased by one if (N+!)th digit is more than 4.
  11. Miner
    578
