Revision in control document
Discussion in 'ISO 9001:2015 - Quality Management Systems' started by Rajan Gupta, Jun 12, 2018.
  1. Rajan Gupta
    Rajan Gupta Member
    May 30, 2016
    44
    hello everyone,
    I have a controlled document of technical specification in which we need to delete some column.
    Please suggest in this case what should we do ?
    Change the version number or maintain the same.
    Also let me know me information when a new document revision number has to be given
    4,546
    2,286
    What is the "column"? Data or simply an extra space in an Excel spreadsheet?
  3. John C. Abnet
    633
    444
    Good day @Rajan Gupta ;
    Consider this...
    1- Once the change is done, if the "old" (prior) version is used by accident,...
    a) Will it cause non-compliance to your internal requirements?
    b) Will it cause a "non-compliance" to your internal intent?
    c) Will it cause a non-compliance to customer requirements/expectations?
    Per @Andy Nichols comment, it is necessary to consider the impact of the change. If I were auditing your company and saw a different purpose/intent/data collection on the form in use versus older copies, then I would be concerned that a change was made with no CPC (change point control). If, on the other hand, and extraneous column or verbiage was simply changed, then I would have little concern.
    What is the "scope" of the organization's process for "control of documented information"? (if your organization has a defined/documented process for "control of documented information"). The reason I ask this question is that I always suggest to my clients that any defined/documented process have an identified "scope". That helps prevent the need to decide in each situation (as it appears is being done here), whether or not the process applies to the situation in question. The "scope" helps identify whether or not a given scenario is applicable to the defined process.
    In addition, I would also ask yourself (the team) if the document structure is controlled, then why NOT simply use the organization's CPC process and update the revision of the document? I'm assuming if the CPC process is designed to be simple to use, then it could have been updated with a new revision in the time it took us to have this forum discussion on the issue... :)
    Hope this helps. Be well.
  4. Rajan Gupta
    Rajan Gupta Member
    May 30, 2016
    44
    Generally it contained some informative data but never used by the relevant department .
    So please suggest what should be done in this case.
    4,546
    2,286
    Delete the column and reissue the document at the next level (a, 2, whatever)
    Candi1024 and John C. Abnet like this.
  6. Rajan Gupta
    Rajan Gupta Member
    May 30, 2016
    44
    do i need to release with new revision code
    4,546
    2,286
    Do you have a document control procedure? What does that tell you to do? It is normal practice, when a document is changed, to indicate the next version on the document.
  8. tony s
    1,270
    968
    If the controlled document (I'm assuming it is a form) has already an assigned document code, then you only need to release the revised form indicating the next revision level. For example:
    If the original Purchase Request Form has an assigned code and revision level of: PUR.F.01, Rev0,
    then the revised version will have the same code but with next revision level of: PUR.F.01, Rev1
    Sunkist S. Leona and Neo113016 like this.
